Travel trailer with a F150 - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
Old 08-18-2014, 10:10 PM
CPL_Guimonster CPL_Guimonster is offline
CPL_Guimonster is starting off with a positive reputation.
Help! I am now confused. went online to Ford and was watching the towed capacities of F150's (super crew 4x4)and a 6.2 with 3.73 will tow 11100 lbs. The xlt and FX4 packages allow this choice. Went to the dealer and i was told that Ford wont have those options and should consider a 250. Is this an elaborate bait and switch? My intent is to tow a 8000lb Travel trailer and a 723lb golf cart (so 6.8'bed is minimum bed size)1-2 times in the summer.
Old 08-18-2014, 10:54 PM
TheStuffz's Avatar
TheStuffz TheStuffz is offline
TheStuffz is gaining momentum as a positive member of FTE.TheStuffz is gaining momentum as a positive member of FTE.
local dealer told me that the numbers are not out yet for towing capacity.
Old 08-18-2014, 10:59 PM
I oops!
i was on 2014 build. obviously to build 2015 will have to wait or buy 2014 used or left over
Old 08-19-2014, 08:11 AM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
For the 2014s, you can get up to 11.3K towing capacity with a properly equipped F150 (EcoBoost, max tow/heavy payload, etc.) However, capacity isn't the only number that matters. You also need to concern yourself with GVWR and GAWR. My concern would be GVWR and rear axle GAWR - you're putting a lot of weight directly in the bed, plus the tongue weight of the trailer, plus whatever you put in the truck itself (people, fuel, etc.) I suspect you will overload the rear axle.
Old 08-19-2014, 08:13 AM
heymrdj's Avatar
heymrdj heymrdj is offline
heymrdj has a good reputation on FTE.heymrdj has a good reputation on FTE.heymrdj has a good reputation on FTE.
Seeing as I don't have any reason to believe that capacities will change at all, we'll use the current F-150 numbers. With the max trailor package, your max payload is 1900 pounds. Subtract 550lbs for the average payload of 2 humans, some gear, and full tank of fuel. So now you're at 1400lbs. The average golf cart is 500-800lbs. Lets just leave it at the smallest, but that's a super tiny golf cart. That's 900lbs of payload left.
Your RV should have 12-15% of the tongue weight on the truck. That's 960lbs. at minimum for an 8K, and to be safe that would need to be a travel trailer with an 8k GVWR, as people tend to have them far more loaded than what the RV dealer tells them it weighs. If you buy an 8K, then furnished and on the road it'll be near 10K when it leaves port.
So what I'm saying is, he's not just doing a sales pitch. If you really want to do what you're saying, you need a 250. All these 1/2tons keep getting more and more capabilities (behind the truck). The problem is the semi-float axles aren't really designed for all that weight. You need the full float bigger axles that come on superduties.
Old 09-12-2014, 03:44 AM
xr7gt390's Avatar
xr7gt390 xr7gt390 is online now
xr7gt390 has a very good reputation on FTE.xr7gt390 has a very good reputation on FTE.xr7gt390 has a very good reputation on FTE.xr7gt390 has a very good reputation on FTE.
A properly equipped 2014 has a max payload of 3120lbs and a max tow of 11,300lbs. The 2015 is lighter so max payload could be higher. How far are you towing? Seems like you would be fine with max tow. I would talk to another salesman.
Old 09-15-2014, 11:18 PM
Heymrdj. (and everyone else!)
what i am finding with my F150/F250 quest is the 6.8 foot bed AND 3.73 rear EGOBOOST max tow is a rare combo.(SCREW).And once i get one I would have to have air bags or add a leafs. Now with a 250 with same combo's (6.2l) and only $350 more than equip 150, all I have to do is turn the key and drive!
Old 09-15-2014, 11:19 PM
Now to try and find a F250 Crew with a 8'bed and everything will fit perfectly!
Old 09-16-2014, 08:30 AM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
I'm a big proponent of using the right tool for the job. Most of us weekend warriors are well within the limits of the F150 platform. However, given how much load you plan on putting in the bed. (723lbs golf cart, plus some gear is over 900 lbs easily). I'd say for you an F250 makes a lot of sense.
It's also nice that you can get and F250 for pretty much the same money as the F150, that's a great deal for guys like you.
Help calculating towing/payload PokerMunkee 6.2L V8 3 06-24-2015 05:21 PM
3/4-ton to 1/2-ton Ecoboost Questions Kalabin 2009 - 2014 F150 8 09-16-2014 08:38 AM
Real World Towing Jonesy0027 2009 - 2014 F150 7 06-09-2014 09:49 AM
2008 F-250 fifth wheel hitch weight bgathey Fifth Wheel & Gooseneck RV Towing 5 10-06-2011 02:07 PM
6.0L mpg for towing a 15,000lb trailer? bigsub 1999 to 2016 Super Duty 6 04-19-2007 05:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
