Reassembling Door Hinges - Ford Truck Enthusiasts Forums
Old 08-18-2014, 10:00 PM
ct50f1's Avatar
ct50f1 ct50f1 is offline
ct50f1 has a great reputation on FTE.ct50f1 has a great reputation on FTE.ct50f1 has a great reputation on FTE.ct50f1 has a great reputation on FTE.
I've got the doors off the cab and the hinges disassembled. The doors are already primed and ready to be painted. I'm thinking I should have put the hinges back together before the doors were prepped for painting. My question is, in what sequence would you reassemble everything? It was such a hassle to get the hinge pins out that I'm afraid when I go to put the new pins in they'll get stuck half way in and I'll mess everything up again. Would it make sense to grind down the knurl at the top of the pin so that they can be removed more easily or would that make the doors too loose on the hinges? I also wonder about when to mount the mirror. I assume after everything is painted and back on the truck but that means removing the pin again. Sorry about all the questions but I can't decide what to do first.
Door Hinge Pins on a "53 F-100 jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-31-2014 12:44 PM
Door hinge interchange 98 Explorer Mikeman Explorer, Sport Trac, Mountaineer & Aviator 0 08-18-2014 10:51 PM
Door hinge rebuild, save some time. lvin4jc 1987 - 1996 F150 & Larger F-Series Trucks 11 09-19-2012 12:59 AM
What do you use to remove door hinge pins? ralphhood3 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 01-07-2012 08:01 PM
FAQ - Door hinge replacement that went well Roamer '80-'86 FAQs (Frequently Asked Questions) 7 05-08-2009 08:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
