better fuel mileage - Ford Truck Enthusiasts Forums
better fuel mileage
Old 08-18-2014, 09:17 PM
chrisb_93 chrisb_93 is offline
chrisb_93 is starting off with a positive reputation.
better fuel mileage
I was wondering how I can get better gas mileage out of my truck its a 1980 f150 300 6 cylinder I've got a 4 speed with overdrive with a 2.75 open rearend with 31 10.50 r15 tires I've been told run it really lean and I can get around 25 miles a gallon I just rebuilt the carter single barrel carb just too rule that out and I don't wanna automatic so I'm open too anything else I'm just curious as too what I can do
Old 08-18-2014, 11:04 PM
Patrick Omally Patrick Omally is offline
Patrick Omally is starting off with a positive reputation.
Quote:
get a vacuum gauge and tune the idle mixture to max vacuum..( and then usually go a slight bit leaner at idle)
then tune the ignition timing to max vacuum...
then tune ??????? check the advanced (2.5k to 3k rpm) ignition timing
if you want to really really do good, get an air fuel ratio gauge 170 from Amazon and install it in the oxygen sensor port.
for MPG the best is to drive slow, and make sure the engine is proper air fuel ratio, and that ignition is occurring at the best time
Old 08-18-2014, 11:20 PM
I have no oxygen sensor port its an 1980 f150 and I tuned the carb after rebuild
Old 08-18-2014, 11:35 PM
How did you tune it? Also I am sure you could add an oxygen sensor port. Air/fuel ratios are really cheap compared to gasoline costs over a year or so.
Have you checked ignition timings?
What does the vacuum gauge say at idle?
Old 08-18-2014, 11:48 PM
Had a friend that owns a shop tune it after I rebuilt it also had compression test done
Old 08-19-2014, 12:34 AM
well he did a good job if it is 25miles per gallon. besides a vacuum gauge and air fuel ratio gauge there isn't much more you can possibly hope for or do on your own..
change the oil and make sure the filters are good and drive safe
Old 08-19-2014, 12:37 AM
I was also wondering if changing the piston rings and head for higher compression would help
Old 08-19-2014, 12:47 AM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
If your willing to do that much work then do aero mods, air damn, bed cover, under pan.
Old 08-19-2014, 01:12 AM
you'd spend 2k dollars, and you might end up having to buy premium gasoline by the time you are finished
have you even done a compression test? if you are not burning tons of oil then you don't need new rings.
Old 08-19-2014, 01:20 AM
I don't burn any oil I just figured I'd replace them soon because they've never been replaced
Old 08-19-2014, 07:26 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Get rid of those big tires and that will help some. Less friction on the road. That's one of the first rules when building a EV. Skinny tires pumped up to the max.
You can also run synthetic oil in the tranny and the rearend.
The "take it easy" suggestion will work well also.
Here's a link to a site with a lot of ideas on the subject.
http://ecomodder.com/forum/showthrea...ehicle-83.html
Old 08-19-2014, 03:08 PM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Check alignment; correct tire air pressure; standard sized tires with non-aggressive tread tires; eliminate all unnecessary weight; make sure brakes are not dragging; check for correct choke operation; does the truck still have the factory air filter housing and the associated hoses [cold and warm air provision]?; remove bulky toolbox or driving lights, properly tuned, clean full sized air filter... etc.
Drive like an old man; short shift... get into the next higher gear as quickly as possible without lugging the engine. Cruise @ 55-62 mph.
"Pretend that there is an egg between your foot and the gas pedal."
1986 F150 w/ 4.9L, 4 speed manual O.D., 3.08 rear gears, Duraspark conversion, no EGR, catalytic convertors still intact plus driving as described above = 17 MPG in town and 22+ MPG highway.
Still working on making it even more efficient! [OK GTG 9/13/14]
Old 08-19-2014, 06:43 PM
FilmCarp FilmCarp is offline
FilmCarp is starting off with a positive reputation.
If you are getting 25mpg I want to know the mpg of the truck pulling you. Seriously, I have never had a full size truck give me 25 mpg.
Old 08-19-2014, 08:09 PM
oneowner83 oneowner83 is offline
oneowner83 is gaining momentum as a positive member of FTE.oneowner83 is gaining momentum as a positive member of FTE.
The OP said he had been told he can get 25 mpg.
Old 08-19-2014, 09:45 PM
Quote:
You are right. I misread it.
PO171 caused by bad thermostat and cold weather? intelisevil 1997-2006 Expedition & Navigator 6 01-06-2017 11:36 PM
need help making informed purchase ginasaltina 1968-2013 Full Size Vans 36 07-25-2015 02:27 PM
Bought a new toy! CG Stoker 2009 - 2014 F150 9 03-20-2015 11:41 AM
Mileage question RobertJohn 1999 - 2003 7.3L Power Stroke Diesel 5 03-09-2014 03:35 AM
May have stumbled on a huge mpg increase for Ecoboost Tow Max QwkTrip 2009 - 2014 F150 21 09-22-2013 06:28 PM
Tags
1980, 300, bullnose, gas, mileage, trannsmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
