subford- FUEL TANK SELECTOR VALVE - Ford Truck Enthusiasts Forums
Old 08-18-2014, 07:20 PM
epdukes13 epdukes13 is offline
epdukes13 is starting off with a positive reputation.
Hey Subford, where's the best place to buy this fuel tank selector valve, O'rielly's or AutoZone don't carry them or they carry the electric type or would the electric type be the best way to go?.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Can it be cleaned out, having intermittent problems with it selecting the rear tank pump?<o></o>
Old 08-18-2014, 08:58 PM
kevin206's Avatar
kevin206 kevin206 is offline
kevin206 is starting off with a positive reputation.
Old 08-18-2014, 09:06 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
Your problem may be the pump in the tank. If it isn't putting out enough, the little valves in there won't switch. Ask me how I know.
Old 08-18-2014, 09:07 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Originally Posted by kevin206 View Post
I just checked with a few FLAPS and all I found were the electric versions, also.
I saw this on Amazon.
Amazon.com: F1uz9b263b Reservoir Assembly - Fuel Selector Valve Oem Ford: Automotive
Amazon has been the best priced supplier of that valve for the last few years. You could disassembling the one you have, sometimes debris gets stuck in the mechanism.
Some good info here from Steve83: 1983 Ford Bronco '84-89 Fuel Reservoirs pictures, videos, and sounds | SuperMotors.net
Old 08-19-2014, 09:21 AM
Quote:
How do you know?
I just replaced the tank pump this weekend.
fuel tank selector switch question metal_man81 1987 - 1996 F150 & Larger F-Series Trucks 9 12-31-2015 04:03 PM
Removin EGR pipe, Pipe thread plug in EXH manifold? JimsRebel Ford Inline Six, 200, 250, 4.9L / 300 2 05-21-2012 10:01 AM
o-ring under oil fill cap?? JimsRebel Ford Inline Six, 200, 250, 4.9L / 300 3 12-31-2011 08:36 PM
90 F150 Engine dies when switched to front tank. FordGumby 1987 - 1996 F150 & Larger F-Series Trucks 13 07-31-2011 05:12 PM
'57 F100 Buildup atothec 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 09-22-2008 03:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
