Mild street motor.
. Don't know if a 'built' 302 is going to seem like any kind of a barnburner in a full size truck... still suggest looking at more cubes...
Ford 289 302 351W 408 427 5 0 Mustang Aluminum Heads GT40 EFI Carburetor | eBay ($599/pair)
. Rebuilding with a 347" kit prolly wouldn't cost much more and give a good boost in torque...
After checking them out, they are stamped GT, not GT40P. All I have researched shows they are GT40 heads, not GT40P.
The 302 in my 1978 F100 is tired and leaky. She needs new life. I am wanting something peppy, and I stopped into a machine shop today that will build my engine into a nice little 306 with a mild Torquer cam for $1,400 including the head work. Now, I have owned several high performance vehicles before, but I have never built an engine from the ground up. So I compiled a list of parts and would like to see what you guys think.
So for starters... Basic Ford 306 with a target of 300 HP and a little more torque.
Intake- Weiand Stealth or Street Warrior dual plane.
Carb- Demon Street Demon 625 CFM 4bbl.
Headers- FLowtech long tube, 1.5" with 3" collector (painted)
Distributor- MSD pro billet
Ignition- MSD
QUESTION I HAVE IS ABOUT THE HEADS...
I can get a set of Ford Racing Turbo Swirl aluminum heads. Should I go for it to meet my needs? Has the list I have out together sound like a working recipe? Any help would be appreciated.
Ignition- MSD
#28
I can tell you this, you can take that $400+ spent on the MSD stuff and apply it to better heads. The stock Ford Durspark is plenty good compared to MSD . As for a peppy street combo, just a plain jane 94-97 5.0 from a pickup or van will be worlds above what you have now, especially after replacing the rockers with 1.7's and adding a fee flowing exhaust. What I would look at in your case is replacing the motor with a 351W first and foremost.
I appreciate the info on the Duraspark. Honestly I have been batting around the idea of ditching the MSD dizzy from the build. Where can I source a Duraspark from?
#30
I am simply not interested in swapping the motor. The truck came with this 302, I am going to use it. I have two fresh 360s that I could build a 445 out of if I wanted to do a motor swap.
