drive train identification - Ford Truck Enthusiasts Forums
Old 08-18-2014, 07:02 PM
roughridn_sob's Avatar
roughridn_sob roughridn_sob is offline
roughridn_sob is starting off with a positive reputation.
Deciphering what Im working with on this 63 I picked up. the left door code i dont think is much use since the registration vin and the vin on the door dont match which kinda sucks. anyway I thought I would have 4.88 gears but found a couple tags that lead me to think otherwise. Ill post up what I have and hopefully yall can help me out. Thanks.
What I do know:
4 speed manual with granny 1st (model #)
spicer model 24 transfercase
Are these dana 70 axles?
I want to try and figure out what size tires I should run to be happy at 65mph. it currently has 37s on it and I havent had it out on the interstate yet but tooling around town it seems ok.
Rear axle plate 1
Rear axle plate 2
Old 08-18-2014, 07:25 PM
TA455HO's Avatar
TA455HO TA455HO is offline
TA455HO is gaining momentum as a positive member of FTE.TA455HO is gaining momentum as a positive member of FTE.
Dana 60 rear end and Dana 44 closed knuckle front end. You can see the "60" just to the lower right of the access cover on the rear.
Same as my two 1966 F250 4x4 trucks as far as housings. Mine are 4.5x geared, but same outside.
Obviously your door tag is wrong if this is factory 4x4 because the F350 wasn't offered in 4x4 other than conversions in 1963.
See if you can find the VIN on the passengers frame rail. Mine are all on the top about even with the alternator. But 1966, again, so 1963 may vary.
The rear axle tag does seem to indicate 1965 so it might have been swapped out. Not positive, just sayin'.
Old 08-18-2014, 07:52 PM
look high and low on the passenger side frame rail no luck. the only other VIN i have is the one on the registration
F26CR342841
Old 08-18-2014, 10:05 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by TA455HO View Post
The rear axle tag indicates 1965 (C5TA-VE) so it has been swapped.
1965 F250 Spicer/Dana 60 / 4.10-1 with Limited Slip.
Quote:
Originally Posted by roughridn sob
The only VIN I have is the one from the registration: F26CR342841
F26 = F250 4WD / C = 292 2V / R = San Jose CA Assembly Plant / 342841 = 1963, assembled October 1962.
Warranty Plate is from a 1963 F350. No F350 4WD's until 1979.
Old 08-18-2014, 10:11 PM
Thanks Numberdummy im all over the place trying to figure out this frankenstein I guess you get what you pay for hahaha. and considering i got the truck for free I think im doing alright.
Im assuming the PO did the swap for better freeway manners
Old 08-19-2014, 09:58 AM
schoo's Avatar
schoo schoo is offline
schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.
The tie rod does not look the same as my truck but the rest looks the same
Does it have the 292 or was that changed, the tranny looks forward on the crossmember that should be mounted at the bell maybe just the angle of pic
Old 08-19-2014, 06:46 PM
schoo the 292 was changed to a 460, deff has a custom crossmember
Cracked dashpad recovering tutorial/ How-to... roughridn_sob 1987 - 1996 F150 & Larger F-Series Trucks 22 09-05-2016 08:49 PM
Is this fixable? roughridn_sob 1987 - 1996 F150 & Larger F-Series Trucks 11 02-01-2016 09:16 PM
1963 F250 craiglist SCORE! roughridn_sob 1961 - 1966 F-100 & Larger F-Series Trucks 9 08-18-2014 06:46 PM
Wheel width roughridn_sob 1961 - 1966 F-100 & Larger F-Series Trucks 15 08-13-2014 12:32 PM
4" Suspension lift kit roughridn_sob 1987 - 1996 F150 & Larger F-Series Trucks 17 05-17-2014 03:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
