AIH Delete - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
AIH Delete
Old 08-18-2014, 05:47 PM
Blue7.3's Avatar
Blue7.3 Blue7.3 is offline
Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.
AIH Delete
I deleted the AIH a good while ago but still get a P0541, now when I deleted the heater I reconnected the blue wire the reports back to the pcm , but still a code I know this is not a problem but just thought I'd try and delete the codes for good .
I made up a wire with 4 470ohm 1/2 watt resistors in line and bolted that to the relay where the blue wire is , and then to earth on the block where it was originally .
Now I have run AE on the w/end and no code so far, has anyone have some input on this , or done something similar .
Old 08-18-2014, 05:56 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Old 08-18-2014, 06:35 PM
Blue7.3's Avatar
Quote:
Originally Posted by ChunderDownUnder View Post
Thanks Brian, looks like they just fitted the earth to the relay mount , i guess the block earth would be the same?
AIH and other questions??? bleeds blue 1999 - 2003 7.3L Power Stroke Diesel 14 05-21-2016 11:49 AM
Glow Plug and AIH relays Absolute 1999 - 2003 7.3L Power Stroke Diesel 10 01-20-2016 02:15 PM
new codes, am i headed in the right direction? Lambert01 1999 - 2003 7.3L Power Stroke Diesel 5 05-02-2014 07:57 PM
Anyone remove the AIH relay and move GPR to fender? BWST 1999 - 2003 7.3L Power Stroke Diesel 33 01-13-2014 09:44 AM
AIH Delete question mybigredford 1999 - 2003 7.3L Power Stroke Diesel 30 06-02-2010 12:30 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
