96 F350 Pull While Braking With Smoke - Ford Truck Enthusiasts Forums
Old 08-18-2014, 06:37 PM
rbhug's Avatar
rbhug rbhug is offline
rbhug is starting off with a positive reputation.
Hi all,
I ran across an issue with my truck last week...
96 F350 CC LB SRW 4x4 7.3
Slowing to turn on to my road and began pulling to the right (toward passenger) each time I applied the brakes. When I parked I noticed smoke coming from the left (driver) side front wheel well. The next day after it had cooled, I pulled the left front tire to inspect. Had my son apply the brakes as I spun the wheel and it stopped, so there is at least a little braking power now since it's cooled. Looks like there's plenty of meat on the pads. No obvious leaks on the brake line. I did lock in the hub and the left side doesn't turn the front drive shaft (but the right side does). Not sure what the hub would do to cause this so that may be a coincidence.
My guess is that something heated up to the point where my brakes on the left front overheated and wouldn't work anymore, then the right brakes were the only thing working.
I figure I'll pull the hub lock cover and see what I can see there. Anything else I should look at?
Thanks in advance for any advice!
Rich
Old 08-18-2014, 06:52 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Likely sticky/seized caliper slide pins. Remove the calipers from the brackets, pull the slide pins out carefully, clean the bores in the calipers, clean the pins, re-grease them with some high-temp grease, and re-assemble.
Also could be caliper pistons sticking in the calipers.
Old 08-18-2014, 07:21 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
+1 on Lead Heads suggestions, sounds like a caliper related issue.
Do the other side while you're at it.
Old 08-18-2014, 09:04 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
A bad brake hose also can cause this issue.
Old 08-19-2014, 02:04 PM
rbhug's Avatar
Thanks all! I'll clean and grease both sides real good and give it a try. Thanks for the suggestions. I'll let you know how it turns out.
Old 12-27-2014, 06:38 PM
rbhug's Avatar
Update
Update - I pulled calipers on both sides. The slides were all rusty and were obviously not replaced by the garage I had take care of my front brakes about a year earlier (while I was having the transmission rebuilt). That's what I get for letting someone else do it. I replaced the pads, new slides, greased properly, bled the brake lines on the front. Been working fine ever since.
Thanks for all the advice
Parking Brake Adjustment CoachMikeSC 2007 - 2014 Expedition & Navigator 2 01-25-2016 10:54 PM
Front end problem... again.. some suggestions/guidance appreciated. Diesel 724 1999 - 2003 7.3L Power Stroke Diesel 4 01-10-2015 07:18 PM
What's going on with my front brakes? redbug 1999 - 2003 7.3L Power Stroke Diesel 25 08-23-2014 06:00 PM
Brake pull. Need help Ghadaz Excursion - King of SUVs 17 12-21-2013 02:02 PM
SMOKING Hub on a 90 F-350 87roadracer 1987 - 1996 F150 & Larger F-Series Trucks 1 04-12-2003 12:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
