PCV Valve Woes - Ford Truck Enthusiasts Forums
PCV Valve Woes
Old 08-18-2014, 06:08 PM
GiantPinkMonkey GiantPinkMonkey is offline
GiantPinkMonkey is starting off with a positive reputation.
PCV Valve Woes
Bought a replacement PCV valve from Autozone the other day and finally got around to installing it. The one I removed had only one port for a vacuum line, but after pulling the new one out of the package it had two (F shaped). Me being inexperienced installed the new one anyway, but now the top vacuum port (smaller one) on the new valve is sucking in air. I guess my question is should it be capped, have a line running to it, broken off, or left open? The truck/motor in question is a 1990 F250 with the 5.8 351w. Any help would be greatly appreciated.
Old 08-18-2014, 08:56 PM
Ok so I've been doing more research, but am still confused. From my understanding the pcv valve I bought is more of a universal one and should have come with a cap for the top vacuum line. Mine did not though. So before I do something stupid and break something I would like to get some reassurance that it should have a cap there.
Old 08-18-2014, 09:02 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
There should have been a small plug in the package to block it . Often attached to the valve itself , must be broken loose and installed . Either way , plug it or cap it .
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Just cap the extra port won't hurt a thing, often the top port universal PCV valve is plugged end of it has to be clipped off if needed.
Sounds like you didn't get that style so a short section of appropriate sized hose with bolt to plug the end will work in a pinch until get a cap for it, or as a permanent fix depends on how fussy one might be about something like that.
Old 08-18-2014, 09:11 PM
fordboy97's Avatar
fordboy97 fordboy97 is offline
fordboy97 is starting off with a positive reputation.
Toss that one and get a motorcraft pcv valve. Much better quality, and no extra ports. I got a new rubber grommet for the valve cover too, made a nice air tight fit.
Tanner
Old 08-18-2014, 09:14 PM
Headed to the store now to buy the motorcraft one. Thanks for the help everyone
Old 08-18-2014, 10:10 PM
fordloco fordloco is offline
fordloco is starting off with a positive reputation.
I always try to use OE motorcraft parts if at all possible and affordable.
Old 08-18-2014, 11:10 PM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Motorcraft only! Other junk, aftermarket PCV valves aren't calibrated correctly and can produce a lean condition or worst!
Decipher The Picture: Help with Vacuum Lines nosehair 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-02-2015 04:07 PM
The Carb / Distributor Conversion & Cleanup KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 35 08-11-2014 04:25 PM
66 f100 352 w/ 3spd vacuum question jlom FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 01-07-2014 05:35 PM
buncha q's... 351m vacuum routing & emissions control brooklyn Fuel Injection, Carburetion & Fuel System 8 08-10-2012 12:23 PM
help with emissions Jodell 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 14 03-05-2009 09:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
