1995 F350 "Dually" with Electrical Issue - Ford Truck Enthusiasts Forums
Old 08-18-2014, 04:27 PM
IdrinkPBR IdrinkPBR is offline
IdrinkPBR is starting off with a positive reputation.
I have a '95 dually and it has small yellow running lights on the rear fenders. The only time those lights will come on is when the headlights are on (or parking lights) and I put it in reverse. Not sure, but I would have guessed they are supposed to on when the lights are on and go out when the truck is put in reverse.
Any ideas??
Old 08-18-2014, 05:30 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
All the ones I have seen are on all the time the headlights or park lights are on. They should not go off at any time unless you turn the other lights off.
I suspect a wiring problem at a trailer plug. Seeing this is a dually, I am sure you probably have trailer plugs, and may even have one in the bed for a goose neck or 5th wheel. Some people's wiring practices are not very good if these where added in later.
If the ground for these little lights happens to be hooked to the reverse lights, they would go out when the reverse lights are activated.
Old 08-18-2014, 06:57 PM
Thanks for the reply. I'll check the things you mentioned. My assumption has always been that these lights would/should go out when you put the truck in reverse because I am blinded by them while backing if I'm using the mirrors, which is just about always. If that's not the case, I may try to figure out a way to set them up that way.
Anyway, thanks again and I'll let you know what I find out.
Old 08-19-2014, 11:57 AM
Franklin2's Avatar
I double checked the diagrams. They do stay on all the time with the other marker lamps. There is a relay somewhere up front that drives all these lamps on a brown/white striped wire.
Old 08-19-2014, 05:25 PM
rickvm rickvm is offline
rickvm is starting off with a positive reputation.
Franklin, I need your help over on thread titled "Tail light, Parking light, Running Light, Dash Light Problems", page 7. Thanks, Rick
Old 08-19-2014, 08:22 PM
Franklin2's Avatar
Quote:
I made a new thread topic for your post so it's easier to find. I took it out of that mile long thread.
Reverse lights Seanosu 1994.5 - 1997 7.3L Power Stroke Diesel 0 03-07-2016 10:59 PM
reverse projector lights aramirez 6.0L Power Stroke Diesel 7 01-05-2016 10:48 AM
Reverse Light Bulbs?? Supercab 6.4L Power Stroke Diesel 5 05-12-2015 11:17 AM
2000 f650 reverse light switch??? pepsiguy Large Truck 5 09-14-2011 07:50 PM
Reverse Lights cray0971 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-25-2011 09:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
