fuel tube on left side... - Ford Truck Enthusiasts Forums
Old 08-18-2014, 03:04 PM
jejch1214's Avatar
jejch1214 jejch1214 is offline
jejch1214 is starting off with a positive reputation.
Question fuel tube on left side...
Hello everyone. I'm running into some issues with my 1989 f150 5.0L...okay...ALOT of issues...seems that the guy that sold it too me lied about everything...last time that I go to buy a vehicle without a compression tester!! ANYWAY, I digress...the fuel tubes on the drivers side frame rail, run about two inches away from my exhaust manifold. The heat melted throught the insulated covering and then the tube on the line running from my tankswitch valve to the left fuel rail. I finally found the part I needed to repair it (more tubing with brass barbs) but, what is the permanent fix? I have no heat shield there (is it missing or just never existed?). Any help with this issue is appreciated as I am not a huge fan of vehicles burning to the ground...
Thanks,
Jeff
Old 08-18-2014, 11:30 PM
UNTAMND's Avatar
UNTAMND UNTAMND is online now
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Seems odd. I thought they were steel or stainless reinforced flex line.
I need to look on my truck, but I thought it went up frame, then jumped over exhaust at the back and hard line up over the bellhousing. Not much plastic.
Any way to take a pic and post it. You'll probably need photobucket where you're not up to 25 posts yet.
Old 08-18-2014, 11:41 PM
jejch1214's Avatar
fuel assembly route...
I will take a pic in the next couple days and post it, but I'm not sure what a photobucket is?
Thank you,
Jeff
Old 08-19-2014, 12:00 AM
UNTAMND's Avatar
Photobucket is a website that you can post pictures to. Then you can use the link to that pic, to post a picture on this site.
I can post a pic directly to the site. But you may not being that you have less posts.
2002 flatbed install hdman6 1999 - 2003 7.3L Power Stroke Diesel 0 11-12-2016 08:09 AM
Fuel: Runs for a few minutes then dies 904man Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 09-23-2015 07:33 AM
EGR Delete Questions johnsonjf 6.0L Power Stroke Diesel 16 05-21-2015 06:20 AM
fuel rails H.E.L.P. chonoman Ranger & B-Series 3 01-07-2015 12:08 AM
1990 460 - 7.5 Fuel Rail Interconnect Help insatiate76 1987 - 1996 F150 & Larger F-Series Trucks 5 07-29-2013 10:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
