1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
05 navigator no start turn key and nothing please help
Old 08-18-2014, 02:45 PM
rob love's Avatar
rob love
rob love is offline
Hey guys new to the forums, so hope someone can help me. 05 navigator no start turn key nothing. I've checked everything I can, I'm a ase tech so all basics are checked. Even took pcm had it bench tested, said it's ok. I can jump starter and truck runs fine, but when I drive it it won't shift, speedo inop and a/c inop too. Original cause was the harness from pcm, melted on exhaust, I repaired the wires and still nothing.. only thing I found was my battery is at 10.6 volts so I'm getting a new one. But can anyone tell me anywhere else to look??? Thanks guys
Old 08-18-2014, 04:50 PM
Jay87LX's Avatar
Jay87LX
Jay87LX is offline
when the harness melted maybe it affected PATS? If the Nav has that ...
Old 08-18-2014, 05:25 PM
alloro's Avatar
alloro
alloro is online now
Received 4,185 Likes on 2,425 Posts
Considering it won't engage the starter nor will it shift, I suggest you test or replace the DTR sensor down on the tranny.
Old 08-18-2014, 05:41 PM
pdqford's Avatar
pdqford
pdqford is offline
Wink
Welcome, Rob.
To get help, we gotta understand the problem.
So when you say "no start turn key nothing", are you saying that when you turn the key, nothing happens,, as in it doesn't crank, it doesn't groan, and there is no clicking noise?
Or do you mean when you turn the key, the starter cranks the engine and the engine doesn't fire?
Maybe if you can help us understand the problem, others will jump in with possible solutions.
Old 08-19-2014, 05:48 AM
rob love's Avatar
rob love
rob love is offline
Alloro sorry bout that.. When I turn key nothing happens just a click from junction box on pass. Side kick panel.. The pats seems to be fine. Doesn't flash rapidly when turning key, and when just sitting the light flashes every 3 sec. Like normal.. thanks for helping me out guys.
Old 08-19-2014, 10:36 PM
pdqford's Avatar
pdqford
pdqford is offline
Ah, so! Sounds like the relay is pulling in. I know you said you checked everything, but does that include the relay to see if it is passing power on to the starter?
Old 08-20-2014, 04:03 PM
Jay87LX's Avatar
Jay87LX
Jay87LX is offline
try jumping the starter solenoid???
Old 08-21-2014, 12:31 PM
rob love's Avatar
rob love
rob love is offline
I jumped starter and it starts fine, then when u drive it it won't shift, and speedo doesn't work. And if I put pedal to floor no acceleration... where is the relay your talking about located? Is it in the junction box on pass. Side?? Thanks again
Old 08-21-2014, 01:08 PM
alloro's Avatar
alloro
I still say inspect/test the DTR sensor.
Old 08-21-2014, 01:25 PM
rob love's Avatar
rob love
rob love is offline
Ok will do.. what does it look like? The dtr sensor
Old 08-21-2014, 05:03 PM
alloro's Avatar
alloro
Watch this video on how to adjust it, it shows it to you. Also, if you want written instructions click the watch on youtube button and click on "SHOW MORE" under the video, right above the comments section.
monsieurharper
2004 - 2008 F150
12-10-2018 09:41 AM
kencrystaljen
16
01-02-2012 08:57 AM
taandctran
16
06-02-2010 10:05 AM
dw1_hoosier
08-22-2004 01:07 PM
transvan
06-22-2004 09:17 PM
Quick Reply: 05 navigator no start turn key and nothing please help
