Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 08-18-2014, 03:45 PM
rob love rob love is offline
rob love is starting off with a positive reputation.
05 navigator no start turn key and nothing please help
Hey guys new to the forums, so hope someone can help me. 05 navigator no start turn key nothing. I've checked everything I can, I'm a ase tech so all basics are checked. Even took pcm had it bench tested, said it's ok. I can jump starter and truck runs fine, but when I drive it it won't shift, speedo inop and a/c inop too. Original cause was the harness from pcm, melted on exhaust, I repaired the wires and still nothing.. only thing I found was my battery is at 10.6 volts so I'm getting a new one. But can anyone tell me anywhere else to look??? Thanks guys
Old 08-18-2014, 05:50 PM
Jay87LX Jay87LX is offline
Jay87LX is starting off with a positive reputation.
when the harness melted maybe it affected PATS? If the Nav has that ...
Old 08-18-2014, 06:25 PM
alloro alloro is offline
alloro is a name known to allalloro is a name known to allalloro is a name known to allalloro is a name known to allalloro is a name known to allalloro is a name known to all
Considering it won't engage the starter nor will it shift, I suggest you test or replace the DTR sensor down on the tranny.
__________________
To thank someone, click the left red "Add to Reputation" button
right of the word "permalink" top right of the poster's message.
Old 08-18-2014, 06:41 PM
pdqford pdqford is offline
pdqford is gaining momentum as a positive member of FTE.pdqford is gaining momentum as a positive member of FTE.
Wink
Quote:
Welcome, Rob.
To get help, we gotta understand the problem.
So when you say "no start turn key nothing", are you saying that when you turn the key, nothing happens,, as in it doesn't crank, it doesn't groan, and there is no clicking noise?
Or do you mean when you turn the key, the starter cranks the engine and the engine doesn't fire?
Maybe if you can help us understand the problem, others will jump in with possible solutions.
__________________
Jim in Central NY
'79 2WD F-150 Lariet w/302,4spd OD, 228,965 mi. (Original Owner!)
'02 4X4 Navigator w/5.4L DOHC 32v Intech V-8 (VIN R).
Old 08-19-2014, 06:48 AM
Alloro sorry bout that.. When I turn key nothing happens just a click from junction box on pass. Side kick panel.. The pats seems to be fine. Doesn't flash rapidly when turning key, and when just sitting the light flashes every 3 sec. Like normal.. thanks for helping me out guys.
Old 08-19-2014, 11:36 PM
Ah, so! Sounds like the relay is pulling in. I know you said you checked everything, but does that include the relay to see if it is passing power on to the starter?
__________________
Jim in Central NY
Old 08-20-2014, 05:03 PM
try jumping the starter solenoid???
Old 08-21-2014, 01:31 PM
I jumped starter and it starts fine, then when u drive it it won't shift, and speedo doesn't work. And if I put pedal to floor no acceleration... where is the relay your talking about located? Is it in the junction box on pass. Side?? Thanks again
Old 08-21-2014, 02:08 PM
I still say inspect/test the DTR sensor.
__________________
Old 08-21-2014, 02:25 PM
Ok will do.. what does it look like? The dtr sensor
Old 08-21-2014, 06:03 PM
Watch this video on how to adjust it, it shows it to you. Also, if you want written instructions click the watch on youtube button and click on "SHOW MORE" under the video, right above the comments section.
__________________
Similar Threads
05 Lincoln navigator no start halofive Expedition & Navigator 4 09-22-2014 10:38 AM
05 navigator no start turn key and nothing rob love Expedition & Navigator 2 06-24-2014 12:15 PM
pcm ecu ecm issue icemaiden Expedition & Navigator 2 02-12-2014 10:25 AM
78 Bronco headlight low beam inop only!! xfordtech Electrical Systems/Wiring 3 08-31-2005 02:01 PM
77 turn signal inop - help jtuck2 Electrical Systems/Wiring 3 01-12-2001 03:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
