2007 Nav not working - Ford Truck Enthusiasts Forums
Old 08-18-2014, 03:37 PM
t_dickie t_dickie is offline
t_dickie is gaining momentum as a positive member of FTE.t_dickie is gaining momentum as a positive member of FTE.
The navigation in my 2007 F-150 is acting up, saying it cannot read the DVD, and that it might be dirty, remove and clean, etc. etc.
Is this a common issue does anyone know?? Also, and perhaps an equally concerning problem is that it won't spit the DVD out. It will get so I can barely see the disc through the mouth of the system, but not enough to grab it. I'm going to try and grab the disc as delicately as I can with a small set of grooveless needle nose pliers, but haven't had a chance to try that yet.
It was doing this a while ago, but seemed to fix itself and hasn't acted up for I'd say 2 months now.
For those that have had this happen before, is it as simple as cleaning the disc, or is this a sign of a larger (possible system failure) problem?? Also I should mention that I still have the original map DVD in the truck, and I think I've taken it out once in the year and a half I've had the truck, and that was just in learning how it came out.
Old 08-19-2014, 01:20 PM
FordIVTteam's Avatar
FordIVTteam FordIVTteam is offline
Official Ford Rep
FordIVTteam has a very good reputation on FTE.FordIVTteam has a very good reputation on FTE.FordIVTteam has a very good reputation on FTE.
Hi Trevor,
It could be as simple as cleaning the DVD; however, since it's also not ejecting properly, I suggest contacting your dealership to determine the cause.
Rebecca
rear dvd player problems jdm5630 2007 - 2014 Expedition & Navigator 22 01-20-2017 03:10 PM
2003 Expedition Eddie Bauer DVD Problems sdixonusa 1997-2006 Expedition & Navigator 2 01-22-2016 12:09 PM
Expedition Rear Entertainment System DVD blinking and draining battery TrollinFord123 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 06-25-2015 01:06 PM
2008 F250 Nav Radio Problem damada Ford In-Vehicle Tech 7 01-23-2014 02:17 PM
2008 F250 Nav Radio Problem damada 1999 to 2016 Super Duty 12 07-17-2013 10:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
