86 302 4x4 - Ford Truck Enthusiasts Forums
86 302 4x4
Old 08-18-2014, 03:29 PM
England1973 England1973 is offline
England1973 is starting off with a positive reputation.
86 302 4x4
I'm looking to see what I can do to beef up my truck a little. It's 4 speed straight drive. I'm already in the process of putting shorty headers on it. I'm just looking to see what else can be done to get if more power. Cam etc...
Old 08-18-2014, 05:38 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Welcome to FTE.
Almost everything you do to an engine raises rpm at which you get peak power. Sometimes you kill low end doing it.
Making the engine bigger, all else remaining the same, lowers the rpm where you get peak power.
That year 302 in trucks was pretty weak at 139 hp if this is correct:
Engine_Specifications
The heads and cam are the problem. The "usual" advice with these is to leave them alone intake wise. The headers will be some improvement, but don't expect miracles.
The "usual" advice is a rebuild with better heads and cam. The other "usual" advice is a swap to a 351W, nearly a bolt in swap.
Conanski is the SBF guru in these threads:
http://www.ford-trucks.com/forums/12...-look-for.html
I'm having some issues with a slow search function today, but you can find all kinds of 302 talk in the SBF forum.
Old 08-18-2014, 06:40 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
that year will have speed density EFI which has some limitations on what performance mods can be done. Exhaust is a great start, also consider having the Y pipe replaced with either an aftermarket or one bent up by an exhaust shop.
what size tires are you running? if your trying to turn bigger meats most engine mods wont help , a gear change will give proper results.
WHERE is my POWER band ??? harley4jcs Modular V10 (6.8l) 4 11-27-2015 04:32 PM
Transmission identification Podaso 1997 - 2003 F150 7 02-22-2015 11:36 PM
Going from 6.0 to 6.4 FL OffRoad 6.4L Power Stroke Diesel 7 02-15-2015 07:57 PM
Holley truck avenger 470 for a 351 351Cleveland C4 Fuel Injection, Carburetion & Fuel System 11 11-18-2014 10:27 PM
What to do? DLH24 1999 to 2016 Super Duty 1 06-22-2014 11:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
