Little Help Quick Question - Ford Truck Enthusiasts Forums
Old 08-18-2014, 01:38 PM
Hop16 Hop16 is offline
Hop16 is starting off with a positive reputation.
Ok so I'm replacing the 4.6 in my 03 explorer at this point motor is sitting in the mounts, transmission is on the dowels all the bolts in the bellhousing finger tight roughly 1/4 to 3/8 gap and still can't locate the torque converter studs am I not close enough messed up gone to far? Please drop some words of advice of possible
Old 08-18-2014, 03:27 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
The studs are prob pressing against the flywheel and they are turning together. Loosen the trans mount and slide the trans back as far as it will go to get a little more room. You may need to wedge something against the torque converter to keep it from turning while you turn the engine. Once you get it lined up and the trans tight against the engine the torque converter should be able to rock back and forth slightly in the flywheel holes. If it doesn't then something is in a bind.
Old 08-18-2014, 04:11 PM
OK thank you will give it a try here shortly if the rain will go away
Old 08-21-2014, 05:20 PM
So I'm having difficulty locating the torque converter as I look the holes for the studs appears everything is rotating together and starter hole plug on the driver side and inspection cover see no where to get anything fingers eyes on somewhere to hold or wedge the torque converter
Old 08-21-2014, 08:50 PM
Maybe pry the engine and trans apart with a large screwdriver while turning the torque converter with a finger, it's a PITA but you got to line it up somehow. Did you slide the trans back?
Old 08-22-2014, 03:14 PM
Yes trans is slide back if the weather plays nicely tomorrow I'm going to float the motor again and see what type of space I can get hope to have it figure out soon just going to need some weather to hold out for me as I'm working outside
Any other suggestions I'm open to all lesson!
Old 08-22-2014, 03:21 PM
Are all of the bellhousing bolts lined up?
Swapping 5.4 to a 4.6 Horseshoe71 Engine Swaps 0 01-16-2016 05:27 PM
4x4 issue Welder7018 1997-2006 Expedition & Navigator 24 08-09-2015 09:06 PM
2001 e350 4x4 ryan peterson 1968-2013 Full Size Vans 4 07-13-2015 01:51 PM
I never seen a 4.4 CAPTAIN DIESEL 3.0L Powerstroke Diesel 17 11-24-2014 01:22 AM
Need 4x4 E4OD JakeMac WTB - Parts & other 0 05-21-2014 11:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
