Shift are measurement from a Factory floor shift FMX
Old 08-18-2014, 01:19 PM
ADOR's Avatar
ADOR
ADOR is offline
Back on the 52 ford again. Got a Gennie Shifter and got it installed, but it's made for a factory FMX with factory floor shift that has the shifter arm pointing up.
My shift arm is pointing down from a column shift car.
Does anyone have the measurement of the length of the factory arm? I am needing it so I can make a adapter bracket and hook the shifter up fully.
Old 08-18-2014, 06:39 PM
71mach351's Avatar
71mach351
71mach351 is offline
The shift arm can be removed and reinstalled facing up. I did it on my fmx to attach to an old mustang shifter. The shift points were off slightly when shifted down to the 1-2 range but seems to line up ok in the p-r-n-d range. It might work with your aftermarket setup. It is a dirty PITA job with the tranny in the truck. Replace the seals when you're in there.
flhx06
09-12-2017 05:25 PM
btdigital
12-31-2008 04:34 PM
kilog55
02-10-2008 03:40 AM
robert collison
03-13-2006 02:57 PM
airharley
03-13-2002 07:23 AM
Quick Reply: Shift are measurement from a Factory floor shift FMX
