PickupTrucks.com 3/4 gasser comparo - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 08-18-2014, 02:04 PM
GoCamping's Avatar
GoCamping GoCamping is offline
GoCamping is gaining momentum as a positive member of FTE.GoCamping is gaining momentum as a positive member of FTE.
At first glance, the F250 6.2 w/ 3.73 gears wins up Eisenhower pass.
Ultimate Three-Quarter-Ton HD Challenge: Eisenhower Pass - PickupTrucks.com Special Reports
But they used different trailer weights? Not sure if I agree with that move... this meant the Ford was pulling 3000lbs less up the grade than the Ram.
I wish they would have kept it all the same, then it could have been more useful to compare.
Old 08-18-2014, 04:42 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
It looks like to me the Dodge is overrated, prob for advertising purposes. A 3/4 ton single rear wheel gas truck should not be rated for 22k lbs IMO.
Old 08-19-2014, 12:11 AM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.
Quote:
Actually, Ram is the only one to be J2807 compliant on their heavy duty trucks, as well as their light duty trucks. The GVWR and towing numbers are entirely accurate as far as the industry standard is concerned. Neither Ford or GM can say that right now.
Old 08-19-2014, 07:32 AM
GoCamping's Avatar
Quote:
Good point, which is why their decision to use different weights frustrates me. Had they been at the same weight, one could extrapolate to the Ford, given that the Ram is J2807 compliant.
I guess I'll have to wait for another test. My plan has always been to buy a used 6.2 when/if I need to move on to another truck but it would be really nice to see how the "older" drivetrain compares to the 6.4 Hemi which has gotten a lot of hoopla...
Old 08-21-2014, 11:11 AM
Mmaxed Mmaxed is offline
Mmaxed is gaining momentum as a positive member of FTE.
I don't place a lot of value in these kinds of tests, but they are interesting.
I am thinking about a new rig and have driven 2 F350s with the 6.2 and one Ram 2500 and one 3500 with the 6.4. All with 3.73 gears. On the test drives the Hemi feels much stronger, but when you put your foot down and the revs come up the 6.2 pulls hard. It is obvious the peak torque on the Hemi is at a much lower rpm, 4600 vs 4000 I think. This gives it a feel closer to my V10.
2017 Super Duty King Ranch at LA Car Show Troy Buenger 2017 Super Duty 4 12-03-2015 01:55 PM
Interesting Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 7 12-19-2014 02:03 PM
Sorry if this is a repost Tofan 6.7L Power Stroke Diesel 3 11-27-2014 09:31 PM
Check out this cool article tseekins 2015+ F150 3 11-17-2014 08:16 PM
Max Towing Wars - Ford vs RAM Troy Buenger 6.7L Power Stroke Diesel 25 07-22-2014 08:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
