4.6 timing problems - Ford Truck Enthusiasts Forums
4.6 timing problems
Old 08-18-2014, 02:03 PM
eddieburnsii's Avatar
eddieburnsii eddieburnsii is offline
eddieburnsii is starting off with a positive reputation.
4.6 timing problems
Engine will only rotate 180 either way (by hand with a ratchet and socket) before something hits internally. Everything seems to be correct as far as I understand. I have attached pics of what I have. Any help will be greatly appreciated.
passenger side cam
driver side cam
crank gears marks are at the 6 o'clock position with the red links on chains lined up
overall pic
Old 08-18-2014, 04:46 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Did you stretch out the chains like l=============l to make the marks? The links on either end are the ones to paint. What happened to make yo take it apart in the first place?
Old 08-18-2014, 05:04 PM
Yes the chains were stretched and marked l========l . It initially blew a spark plug out of the #3 cylinder. The head was removed to fix. After initially getting the timing incorrect and breaking 3 valves and bending one, my friend got a "new" used head for it. After sitting for awhile he is back to messing with it and is hoping to not repeat any mistakes.
Old 08-18-2014, 07:23 PM
If its in time then something has to be on top of a piston or maybe a rod got bent and the piston skirt is hitting a crank counterweight. I know it's too late but there are repair kits for the stripped spark plug holes that don't require removing the head. Cal-van makes a very good kit and I have installed maybe 20 and have not had one come back.
Took the baby out to the mountains. gfburke 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-05-2015 03:39 PM
Almost done :-) jco69 1961 - 1966 F-100 & Larger F-Series Trucks 4 06-18-2015 09:08 PM
project "fat fender ford" pepi_88 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 03-22-2015 11:12 PM
slight delay in new 2015 shipement TheStuffz 2015+ F150 23 12-26-2014 12:06 PM
1968 F100 Trent_Lalonde Manitoba / Saskatchewan Chapter 11 11-27-2014 02:31 PM
Tags
4.6, cam, chain, crank, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
