What is a rough cost? P0677 - Page 2 - Ford Truck Enthusiasts Forums
Old 08-18-2014, 04:33 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
I'm splitting hairs over the difference between the scanner and tuner. Many scanners can turn off the CEL and clear the code. A tuner on the other hand will program the PCM to ignore the sensor input that causes the CEL (or modify it) so you won't be repeatedly clearing the code, it won't pop up in the first place. I also agree the valve should stay connected and if you delete the EGR cooler leave the valve installed in the intake.
Old 08-18-2014, 05:01 PM
Courtney Williams's Avatar
Courtney Williams Courtney Williams is offline
Courtney Williams is starting off with a positive reputation.
On the SGII when it says clear code, does that really clear it? It will just come right back up when I "clear" one.
Old 08-18-2014, 05:26 PM
It does clear it but it will come back.
Old 08-18-2014, 05:28 PM
So when it doesn't come back and I havn't done anything its just fixed itself then?
Old 08-18-2014, 05:36 PM
Rick.charters's Avatar
Rick.charters Rick.charters is offline
Rick.charters is starting off with a positive reputation.
Just an FYI, if you do go the SCT route, Amazon has them right now for $333.00. Rather than $379.00.
It fluctuates, I got mine 2 months ago from amazon, new, and paid $307.00 so watch for better prices.
Old 08-18-2014, 05:38 PM
Ok that is good info, thanks!
Old 08-18-2014, 05:39 PM
Not really, the conditions required to set the code haven't happened again yet. Throttle position, engine load, rpm, coolant temp and commanded EGR position, have to be above specific values while EGR flow as measured by the iat2 and possibly MAF have to be below a specific value and it has to stay that way for a certain amount of time and then "bing" there's the light. And if that isn't complicated enough, many codes require all the values to be outside the allowable limit a certain number of times (usually 3) before turning on the light. While it's counting 1-2- times (before the CEL is turned on) the code can still be pulled with a scanner although it is referred to as a "pending" code.
Old 08-18-2014, 05:42 PM
That makes sence. That is why my truck ran until the truck got to temp and the valve opened and failed the first time.
Old 08-18-2014, 05:51 PM
What is the differnace between the 3015 and 7015 tuners?
Old 08-18-2014, 07:14 PM
Quote:
I can not answer that, hopefully someone else can chime in for us, but everything I have read says that the 3015 is the way to go.
Old 08-19-2014, 10:32 AM
Heading to the shop last night and had a real lack of power with lots of black smoke.. I heard back from the mechanic around 10 and he said the only thing coming up was that glow plug #7. Is it very common to have lack of power and black smoke? I'm giong EGR delete route with blue spring upgrade while im at it.
Want to do the oil cooler soon too, it usualy stays between 15 degrees but when im on a long hard pull towing it can go further..
Old 08-19-2014, 10:58 AM
Heading to the shop last night and had a real lack of power with lots of black smoke.. I heard back from the mechanic around 10 and he said the only thing coming up was that glow plug #7. Is it very common to have lack of power and black smoke? I'm giong EGR delete route with blue spring upgrade while im at it. Want to do the oil cooler soon too, it usualy stays between 15 degrees but when im on a long hard pull towing it can go further..
Your oil cooler, if you stay between 0-15 degrees unloaded at 65mph for 20 min flat ground, is good. I had mine done in April and towing 8k up and down Horseshoe bend hill in the heat I can get an almost 25-30 degree spread. But unloaded it's spread is about 10 degrees.
If you end up needing a different shop, Master Tech Diesel Injection on Cole Rd across from Costco is really good!
  #28
Old 08-19-2014, 11:19 AM
OK I think im good then, unloaded I am always bwtween 10 most of the time its only off by 3.
I'll have to keep them in mind, I like Big Twin Diesel too but they are booked out. I feel like I struck gold being refered this guy, I dropped my truck off at 6:30 and had a call that the major issue was found and fixed by 9. Now just to do the extra stuff I wanted done.
  #29
Old 08-19-2014, 11:53 AM
OK I think im good then, unloaded I am always bwtween 10 most of the time its only off by 3. I'll have to keep them in mind, I like Big Twin Diesel too but they are booked out. I feel like I struck gold being refered this guy, I dropped my truck off at 6:30 and had a call that the major issue was found and fixed by 9. Now just to do the extra stuff I wanted done.
Nice! You will have to tell me who he is!
Power loss issues, and cold start issues. armyprop 6.0L Power Stroke Diesel 13 07-22-2016 09:35 PM
6.0 no start D Craig 6.0L Power Stroke Diesel 16 03-28-2016 01:08 PM
Bad GPR? Need guidance sLackuR 1999 - 2003 7.3L Power Stroke Diesel 9 01-14-2016 07:34 PM
CODE: P0677 Glow Plug problem kelsey344 6.0L Power Stroke Diesel 6 04-30-2012 10:43 PM
p0677 notabeanr 6.0L Power Stroke Diesel 0 02-09-2012 03:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
