Play in steering wheel - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-18-2014, 09:47 AM
tvannaman2000 tvannaman2000 is offline
tvannaman2000 is starting off with a positive reputation.
I have a '99 F250 w/ PSD with 165k miles.
When I drive, I move the steering wheel and nothing happens for the first few degrees of turn and then I encounter resistence and it turns. It's the same either way. The vehicle seems to track nicely, doesn't pull to either side, just a lot of slop in the steering wheel.
Is there a way to determine if this is really steering related or is it just loose/worn front end suspension parts making themselves known? My guess is suspension items, but the fact the front end behaves itself when the truck is moving has me doubting that just a bit.
Thanks,
Tim.
Old 08-18-2014, 09:53 AM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
The steering components would be the first place to look. Ball joints, tie rod ends, etc. If that all checks out, it could be in the steering box. Is your truck a 4x4? And has the front end been rebuilt before? I had my 02 done back over the winter for the first time with close to 140,000 miles on it.
Old 08-18-2014, 09:54 AM
VindexInjuriae VindexInjuriae is offline
VindexInjuriae is starting off with a positive reputation.
Steering gear - they're a known/common issue. It can be adjusted via the allen bolt in the top of the gear, but that's a temp patch more than anything. A lot of members here seem to like the Red Head steering gears when they replace the worn stock part....
Old 08-18-2014, 01:10 PM
Great info... now, someone needs to post how to replace or adjust a steering gear!
Old 08-18-2014, 01:12 PM
[quote=CampSpringsJohn;14592521] Is your truck a 4x4? And has the front end been rebuilt before? [quote]
It is a 2WD and idk about the front being rebuilt. I just bought it several weeks ago, but I would guess that no work has been done it. Carfax showed no accidents.
Old 08-18-2014, 03:56 PM
On top of the gearbox is an allen screw with a lock nut. You back off the lock nut, making sure to watch the allen screw. If it moves, then you need to move it back from where it was when you broke the lock nut loose. Then you tighten it about 1/8 to 1/4 turn, and tighten the lock nut, making sure the allen screw does not move. Then take it for a test drive and see if that fixed it. Before doing this, I would make sure everything else is in good shape. If you over-tighten the gear box you will create bigger problems.
78 F100 power steering nann69 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-08-2015 05:49 PM
89 f150 6cyl ignition switch test elkarcher1716 1987 - 1996 F150 & Larger F-Series Trucks 38 05-21-2015 01:12 PM
Steering Noise Suprawill1 Escape & Escape Hybrid 5 10-14-2014 12:57 PM
89 F350 Steering Pulls When Moving SomeDude451 1987 - 1996 F150 & Larger F-Series Trucks 4 10-03-2014 05:29 PM
Front end pop / clunk! Ball joint? volthause Excursion - King of SUVs 6 12-17-2012 08:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
