05 navigator no start turn key and nothing please help
Hey guys new to the forums, so hope someone can help me. 05 navigator no start turn key nothing. I've checked everything I can, I'm a ase tech so all basics are checked. Even took pcm had it bench tested, said it's ok. I can jump starter and truck runs fine, but when I drive it it won't shift, speedo inop and a/c inop too. Original cause was the harness from pcm, melted on exhaust, I repaired the wires and still nothing.. only thing I found was my battery is at 10.6 volts so I'm getting a new one. But can anyone tell me anywhere else to look??? Thanks guys
Welcome, Rob.
To get help, we gotta understand the problem.
So when you say "no start turn key nothing", are you saying that when you turn the key, nothing happens,, as in it doesn't crank, it doesn't groan, and there is no clicking noise?
Or do you mean when you turn the key, the starter cranks the engine and the engine doesn't fire?
Maybe if you can help us understand the problem, others will jump in with possible solutions.
monsieurharper
2004 - 2008 F150
12-10-2018 09:41 AM
taandctran
16
06-02-2010 10:05 AM
dw1_hoosier
08-22-2004 01:07 PM
