subford- FUEL TANK SELECTOR VALVE
Old 08-18-2014, 07:20 PM
epdukes13's Avatar
epdukes13
epdukes13 is offline
Hey Subford, where's the best place to buy this fuel tank selector valve, O'rielly's or AutoZone don't carry them or they carry the electric type or would the electric type be the best way to go?.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Can it be cleaned out, having intermittent problems with it selecting the rear tank pump?<o></o>
Old 08-18-2014, 08:58 PM
kevin206's Avatar
kevin206
kevin206 is offline
Old 08-18-2014, 09:06 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
Your problem may be the pump in the tank. If it isn't putting out enough, the little valves in there won't switch. Ask me how I know.
Old 08-18-2014, 09:07 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Originally Posted by kevin206
I just checked with a few FLAPS and all I found were the electric versions, also.
I saw this on Amazon.
Amazon.com: F1uz9b263b Reservoir Assembly - Fuel Selector Valve Oem Ford: Automotive
Amazon has been the best priced supplier of that valve for the last few years. You could disassembling the one you have, sometimes debris gets stuck in the mechanism.
Some good info here from Steve83: 1983 Ford Bronco '84-89 Fuel Reservoirs pictures, videos, and sounds | SuperMotors.net
Old 08-19-2014, 09:21 AM
epdukes13's Avatar
epdukes13
How do you know?
I just replaced the tank pump this weekend.
Casey429
05-04-2016 07:36 PM
epdukes13
09-15-2014 09:53 AM
skapford
13
08-03-2013 11:32 PM
macman85602
10-03-2010 12:48 PM
vp96Bronco
01-18-2008 08:38 AM
Quick Reply: subford- FUEL TANK SELECTOR VALVE
