OIL winter F150 2006 - Ford Truck Enthusiasts Forums
Old 08-18-2014, 05:32 AM
SwedMartin SwedMartin is offline
SwedMartin is starting off with a positive reputation.
Hi I am a new owner of a Ford F150 -06, imported to Sweden from Carlifonien.
Is it a good choice to use Gulf Ultra Synth X 5W-20 engine?
Only a dealer that sells Motorcraft in Sweden and it is far from me. it is also very expensive 1 quart = 20 Dollars
It is not impossible that it will be -5 degrees Fahrenheit,
Grateful for info.
Sincerely
Martin Berglund
Motala, Sweden
Old 08-18-2014, 12:17 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
While I am not personally familiar with Gulf oil products it appears to meet the SN and GF-5 specifications so it should be perfectlyl acceptable for your truck. There's no reason you would have to use Motorcraft oil.
Old 08-19-2014, 09:51 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
EDIT: BTW, Welcome to FTE.
This link is to a Gulf recipe/formula that meets Fords specifications & would be a direct replacement for the Motorcraft 5W-20 for your F-150. http://www.nu-tierbrands.com/images/...FE_08-2013.pdf
It has a low cold temperature viscosity that should offer easy starting in cold weather.
Post a link to the Gulf product data sheet on the formula you named above, or select a product number from this link Engine Oils - Gulf Lubricants & we can look it up to see if it'll meet the specifications for your 06 Ford F-150 engine.
2012 F150 5.0 - Advice needed Ekkehard 2009 - 2014 F150 6 01-24-2016 07:33 PM
Transfer noise Mangi Modular V8 (4.6L, 5.4L) 0 01-12-2016 05:55 AM
F 350 2004 parking light Dahlgren 1999 to 2016 Super Duty 5 06-18-2015 04:39 PM
OT. Do you live in Scandinavia? jimcar-9 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 05-17-2015 01:43 AM
What kind of oil in DANA 21 transfer case kalsong 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-07-2009 02:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
