1996 F350 XLT 4x4 Reg Cab 7.5l Auto 106k *NEW PICS* - Ford Truck Enthusiasts Forums
Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Old 08-17-2014, 10:02 PM
Soarer Soarer is offline
Soarer is starting off with a positive reputation.
Year: 1996
Make: Ford
Model: F-350
Price: $6750
Mileage: 106000
Color: White
Private or Dealer Listing: Private Listing
Location (State): CT
Transmission: Automatic
Drivetrain: 4WD & AWD
Color: White
Engine: 7.5 liter gas
Located in Danbury, CT 06810. Very clean F350 lightly used as a supervisor's truck for most of its life. Power locks and windows, sliding rear window, automatic, 4X4, 7.5 liter gas engine with tons of power and torque, alloy wheels with Firestone tires, trailer hitch, air conditioning, XLT package.
Maintenance performed: new battery, new alternator, new brake booster, valve cover gaskets, exhaust gaskets, stainless steel exhaust manifold studs, EGR pipe, plugs, wires, cap, rotor and oil pan. Intermittent CEL which I believe is being caused by a vacuum leak. I'll be sorting this out ASAP. AC stopped blowing cold over the past few months. There must be a minor leak somewhere. The AC compressor and clutch are in good working order.
I just completed a major service on the engine. If you read up on these motors you'll see that a common issue is the exhaust manifold studs break when trying to remove them. I was fixing an exhaust manifold leak and had this issue so I pulled the engine, removed the heads and sent them to the machine shop to be completely reconditioned. They milled them, removed all broken manifold studs and did a complete valve job. I cleaned the motor thoroughly including removing all carbon deposits from the pistons and then reassembled the engine with new gaskets and stainless steel exhaust manifold studs so this issue wouldn't happen again. The engine makes great oil pressure and runs cool. No smoke, knocks or ticks.
The truck drives great and is rot free. The frame is 100% solid and the body is very clean. Try to find another 90s F-Series truck that doesn't have rot holes over the wheel wells! There are a few very small bubbles coming through under the paint in the typical spots but as you can see from the pics below, they are barely even noticeable. Both gas tanks work great. The bed liner has kept the bed in excellent shape as well although it hasn't seen a whole lot of use. Like new tailgate off a rust free truck. Four wheel drive works great. The exhaust is solid and brakes were done recently too. Always starts and runs strong.
I pride myself on being straight forward and honest when selling a vehicle. I am a "no surprises" kind of guy. If you're interested in this truck and want to get a very thorough walk-through of it, just drop me a PM with your phone number and I'll give you a call and tell you everything I know about it; good and bad.
Asking $6,750 OBO
Old 08-18-2014, 06:20 PM
Nathan Nathan is offline
Nathan is starting off with a positive reputation.
PM sent.
Thank you.
Nathan
Old 08-18-2014, 11:30 PM
new pics above
Old 08-19-2014, 07:59 AM
The truck got a new windshield today. The corners of the glass had started to get cloudy so I took it to a Safelite shop to have it replaced. I will only go to Safelite because they are the best and do a much much better job than some of those cut rate mobile glass companies. They use the best glass and their work is second to none. I wanted it to be done at their shop so they would have all their tool and extra sets of hands available to get it 100% correct.
Old 09-08-2014, 03:23 PM
Bump for new pics.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
1996 cc refurbish/psd swap coreylasalle 1994.5 - 1997 7.3L Power Stroke Diesel 239 07-28-2016 04:33 PM
The 1996 F350 CCLB 4x4 Bruster Build rockdawg84 1987 - 1996 F150 & Larger F-Series Trucks 28 09-19-2014 03:00 AM
Crew Cab Rear Door Actuators rockdawg84 1987 - 1996 F150 & Larger F-Series Trucks 10 04-15-2014 03:01 AM
Heater Bypass Mod: Cooler A/C! Bubba Jones 1978 - 1996 Big Bronco 24 03-19-2014 11:55 PM
Culver City Car Show 2013.... 37 Ford guy 1961 - 1966 F-100 & Larger F-Series Trucks 5 05-12-2013 08:13 PM
