well that was an easy pyro install but a few questions - Ford Truck Enthusiasts Forums
Old 08-17-2014, 09:01 PM
brokeasajoke brokeasajoke is offline
brokeasajoke is starting off with a positive reputation.
Put my banks pyro in today. Went well. Drilled and tapped hole almost at #8 cyl. Drilled three times stepping up bit size each time. The threadig went easier than expected also. Its amazing how fast it will go from 200 to 800deg. Now a few questions. My wire coming from the guage(not the prob pigtail) is very long. Can i shorten it? I have like 3 or 4 extra feet of wire. Should i trust the guage or is there something i can test it against? Should i put antiseize on the probe threads? Thanks all
Old 08-18-2014, 12:30 AM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Yeah, you can shorten the wire without issues.
Old 08-18-2014, 09:33 AM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
NO do not shorten pyrometer wiring! It is chromel-alumel wiring and is calibrated!
simply roll the the extra wire and tywrap it out of the way under the dash
Old 08-18-2014, 12:53 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
x2 !!! DON'T cut the wires. Its good to have extra, just find a place where it won't get tangled and tie it up.
anti-seize on the probe threads is a really good idea. But not on the wire connections. Those should be covered up with tape so they won't get corroded.
Old 08-18-2014, 04:37 PM
The wire had been cut. At least 6 in is missing. Will that adversely affect accuracy? Im blowing black at wot but plan on a turbo install as soon as i can get some time so didnt wanna turn it down just yet
Old 08-18-2014, 04:43 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Depends on the wiring. My isspro said that you can shorten it no problem. If the wire is 1 piece with a pigtail id leave it. However if its bare wire on one end im sure you can shorten it. I anti-siezed my thermocouple threads.
Old 08-18-2014, 05:01 PM
sjwelds's Avatar
sjwelds sjwelds is offline
sjwelds is starting off with a positive reputation.
My hypermax combo gauge (made by isspro) came with the ring terminals on the pigtails and instructions not to shorten the wire.
Old 08-18-2014, 05:06 PM
No power wire to gauge. 3 wires. Two insulated and one bare copper wire that goes to one bof the two ring termainals were gauge wire and probe wire come together. Those 3 wires are inside of a plastic sleeve.
Old 08-18-2014, 09:37 PM
Sounds like my isspro. My banks has the ring terminals on each end, and cannot be shortened without throwing off the gauge.
Old 08-18-2014, 10:51 PM
Mn banks did also. I had to put ring terminals back on the cut wires. It does work however, just dont know its accuracy
Old 08-18-2014, 11:44 PM
Macrobb's Avatar
All of the probes I've seen have a separate piece of wire attached; the section that cannot be changes is inside the probe where the two pieces of dissimilar metal are attached.
A pyrometer probe is a thermocouple; thermocouples produce greater voltage with higher temperatures. As long as your gauge is high resistance, the minor amount of resistance from adding extra wire(or less resistance from removing it) shouldn't affect the end result much.
The only thing I can think of is that some gauges don't have an added power source, so they would be driving the meter directly from the current produced from the thermocouple... this might well change it with added/removed resistance.
I've never had issues with that, even with adding 6' or so of 12-ga copper wire to the end of my leads... but I'm using a digital gauge with outside power source, so it's not producing a load on the thermocouple.
Note: On mine, I've tested a couple ways: 1, when cold, it's pretty close to outside temperature(+-10F)... which would be the worst case for a thermocouple(lowest output voltage). 2. EGTs get into the same range as when I had a different probe in.
Old 08-19-2014, 05:02 PM
Seemed to idle about 200 today very easy ever so light throttle running 40 produced 300 and a very steep 1.5 mile grade i drive daily pushed 975-1000 at about 50 mph without blowing black smoke. Flat ground at 50 ish got me in the 500 range. Im still amazed at how fast things heat up. A pyro should be standard equipment in a diesel.
Old 08-19-2014, 07:30 PM
Sounds like its about right.
pyro guage hdman6 1999 - 2003 7.3L Power Stroke Diesel 3 09-09-2016 06:17 PM
Pyro sensor relocatiom tractoman 1994.5 - 1997 7.3L Power Stroke Diesel 3 09-21-2015 08:43 PM
pyrometer broken, or wiring issue? Ezalycasaid 1994.5 - 1997 7.3L Power Stroke Diesel 6 05-20-2015 05:22 PM
Pyro temp probe melted after intall..... KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 3 04-13-2014 03:59 PM
AIH delete plug for boost guage install? fei1 1999 - 2003 7.3L Power Stroke Diesel 7 02-09-2006 10:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
