1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2004 expedition speedometer and shifting problem
Old 08-17-2014, 07:15 PM
dlsoc3's Avatar
dlsoc3
dlsoc3 is offline
Recently replaced my bad transmission with a junk yard transmission. Now the speedometer does not work and won't shift past 2nd gear. Speedometer only reaches 10 mph when actually traveling about 45. Have already changed speed sensor on transmission and did a reset of the pcm. Need some help please.
Thanks
Old 08-18-2014, 05:36 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
Did you change the input sensor by mistake?
Old 09-08-2022, 03:16 PM
Billynthewoods's Avatar
Billynthewoods
Billynthewoods is offline
1st Gear
Did you figure out the issue ? I am having the exact same problem . I know the transmission i installed was working in the vehicle i removed it from . But now , wont shift and speedometer is not working
Nuckleman
12-07-2017 10:52 PM
Bucky623
1997 - 2003 F150
09-13-2016 02:56 PM
dlsoc3
Electrical Systems/Wiring
08-17-2014 08:02 PM
TPM
1999 to 2016 Super Duty
04-12-2007 08:21 PM
jimmick
Aerostar
06-11-2003 06:10 PM
Quick Reply: 2004 expedition speedometer and shifting problem
