Aerostar axle widths and type? - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 08-17-2014, 07:30 PM
carnuck carnuck is offline
carnuck is starting off with a positive reputation.
I'm looking for a replacement diff for my "other" truck that is fairly strong (9" or 8.8), 4.10 ratio and correct width (@60") with 5 lug pattern. Explorer is close but the ratio seems hard to find or very expensive.
Old 08-23-2014, 07:05 PM
asavage's Avatar
asavage asavage is offline
asavage is starting off with a positive reputation.
I had a 4.10 Trak-Loc in my '89 EB, but they're a 7.5" and definitely not strong. The Trak-Loc version tends to oval one of the spider shaft bores in the ring carrier and you get a rattle. And mine had significant decel pinion bearing noise at around 300k miles.
Is the 8.8" from a 4.0l 2WD Aero available in 4.10 ?
[later]
I don't think so. The only 4.10 ratios I see are for the 7.5" diffs in Aeros, according to this list I got from somewhere years back. The comments are not mine:
Old 08-24-2014, 04:49 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is online now
xlt4wd90 is gaining momentum as a positive member of FTE.
Gee, did some Aerostars actually come with aluminum rear axle housings? I know the front axle on my AWD is a Dana 28, and I think it is aluminum. But I don't think I've ever seen one with an aluminum rear axle housing.
Previously I had looked for LSD 8.8" axles with 3.73 ratio, and could not find any. If your list is all-inclusive, that explains why. I was hoping to replace the 7.5" rear axle with an 8.8" of the same ratio, and with a LSD.
Old 08-24-2014, 07:56 PM
asavage's Avatar
I got that list -- with the comments attached -- off the internet, it's not my quote or research.
I don't think the Dana 30 is a rear diff.
Old 08-25-2014, 12:43 AM
RojoStar's Avatar
RojoStar RojoStar is offline
RojoStar is starting off with a positive reputation.
The 8.8 3.73 LSD can be found on the Explorer D4 axle, and mine is still waiting for adaption to the Aero.
Comes with disc brakes too.
Project delayed until early 2015, to be usable by summer.
Old 08-25-2014, 03:12 AM
xlt4wd90's Avatar
I knew they must exist somewhere.
How are you planning to make the adapting?
Old 08-25-2014, 09:48 AM
RojoStar's Avatar
Yes, I'm an engineer with a welder, and my Exp front brake adaption is still working flawlessly.
The big-tube 8.8 w/discs is way heavier than the Aero 7.5.
From lifting just one end, I expect the total to come in at around 250lbs.
Surprise, this '97 example needs to be widened, not narrowed, to match the Aero track.
If and when, the project will go into the Built-to-tow thread.
Old 08-25-2014, 06:47 PM
xlt4wd90's Avatar
Maybe you've posted this before, and I missed it, but can you describe your front brake modification? Or provide a link to anything you've posted before?
Old 08-25-2014, 07:07 PM
RojoStar's Avatar
I'm sure you'll remember Explorer Brakes On An Aerostar.
Fronts currently overshadow the weaker (10") rear drums.
The inbound rear discs will then become too strong with the stock MC and need the Exp MC to balance correctly.
And one Exp MC has bias adjust.
Old 08-26-2014, 09:04 PM
xlt4wd90's Avatar
Thanks Rojo, I can't believe I forgot about that. (and I've commented on it as well).
Rear diff oil capacity? Tony Lee 1999 to 2016 Super Duty 11 02-11-2016 09:09 PM
ranger rear end widths wildstang Ranger & B-Series 15 05-17-2015 08:28 AM
f3 axle width question jamesadams 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 04-09-2015 01:59 PM
Ecoboost axle ratio firejack8 2009 - 2014 F150 11 02-19-2015 04:54 PM
Info needed about rearends 351Cleveland C4 1961 - 1966 F-100 & Larger F-Series Trucks 14 10-02-2014 05:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
