What is this or name that part - Ford Truck Enthusiasts Forums
Old 08-17-2014, 07:17 PM
kduke kduke is offline
kduke is starting off with a positive reputation.
Working on removing excess stuff from my truck, its been modified over its life and has lots of unused extras just left in place.
One was this hose with a spark plug shoved into the end of it
When looking at it, it broke off at the other end...
Bad photo but there is metal inside that end which came from...
Now the question is, what is that? Its located at the rear of the engine, 460, and can be seen in this photo for reference
I assume this isn't a mission critical part since it was so lovingly capped with a spark plug. Part of the factory ac? Has metal tubing come into and out the bottom of that piece, and the hose came out the top and went, somewhere...
The 460 isn't original, was put in who knows when since 1973, into my F250
Old 08-17-2014, 07:24 PM
dragracer1956's Avatar
dragracer1956 dragracer1956 is offline
dragracer1956 is starting off with a positive reputation.
i believe that is a one way valve for the smog pump that pumps air into the combustion chambers to reduce emissions. There should be a steel line that goes to the back of both heads and that valve is attached to it
Old 08-17-2014, 08:03 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Your bottom photo is the PCV. Positive crankcase ventilation. It's there to evacuate the fumes out of the crankcase. You don't want to plug it off or remove it.
Old 08-17-2014, 08:23 PM
brian1080's Avatar
brian1080 brian1080 is offline
brian1080 has a good reputation on FTE.brian1080 has a good reputation on FTE.
I think he put the bottom pic to show where the piece in question goes. Look just past the PCV and you can see the can that the hose broke off from.
I was going to say emissions as well. I take all that crap off of my trucks. :P
Old 08-17-2014, 08:30 PM
Yeah right behind the pcv in the bottom photo you can see the part in question that broke. If is is part of the smog pump can you just remove all that and cap it off? Is it going to hurt anything having that piece exposed like that? Dirt and such getting into it, etc?
Old 08-17-2014, 08:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Emissions related. This is a 302, but you get the idea.
Old 08-18-2014, 01:01 AM
OldMetal's Avatar
OldMetal OldMetal is offline
OldMetal is gaining momentum as a positive member of FTE.
It's called a anti backfire valve if I remember correctly and was connected to the smog pump.
Old 08-18-2014, 01:52 AM
Thanks for the replies guys! After having a point of reference I found it and lots of info, and is indeed all smog related. My truck has had all that ripped off it so going to remove it and plug the holes in the heads.
Even found a post made by NumberDummy given the part number for the plug. http://www.ford-trucks.com/forums/81...block-off.html
Trying to dig around and find an answer to my next question but nothing yet, is it going to hurt anything driving with that open like that? I assume not since that was where emissions were pushed back out of the engine?
Old 08-18-2014, 07:32 AM
Plug the heads and scrap the smog pump,on some 460's they had 2 smog pumps and you should be good.If you really want to wake that motor up change the timing gears to an early70's timing gear set for a 429-460. I believe the where run straight up and yours has 4-7 degrees retard already built into it, unless it has already been changed.
Old 08-18-2014, 11:03 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
D4VY-9A487-A .. Exhaust Air Supply Check Valve
Misc 1974/79 300/302/351W (Econoline)/460 engines.
Old 08-18-2014, 12:26 PM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
We're that pipe mounts to the back of the head, you would need a block off plate, bolts hold them on, I usually unbolt the pipe from the back of both heads, and cut the pipe off, mig or braze the pipe shut and remount the flange part of the tube back to the head, maybe someone made a block off kit like some fuel pumps but I doubt it. You will have to reuse the mounting part so be careful when you RIP it out.
Old 08-18-2014, 02:33 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
No co425 back here in the red box....sorry had to.
Old 08-18-2014, 02:41 PM
David7.3's Avatar
Where is the beer?
That's like a smack in the face, i hope he shaved. You got some nice looking rides there those late 70's were my favorite, My 86 did a great job, but from going from the 6.9 to the power stroke. WOW
Old 08-18-2014, 02:49 PM
77&79F250's Avatar
Used OEM parts guy
Thanks, I love that body style too.
No, he has a good sense of humor, I hope.
He's off line now, so the fun part will be later, ya have to liven things up a bit every so often.
Old 08-18-2014, 02:52 PM
David7.3's Avatar
Where is the beer?
You must know him, if that ain't bust'n ***** I dont know what is, but I like I like
Local spring show theodore/teddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-09-2016 08:14 PM
Teddy's new Interior and tunes theodore/teddy 1957 - 1960 F100 & Larger F-Series Trucks 14 04-20-2016 04:55 PM
1980 460ci ?? r8er4ever Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 05-30-2015 07:08 PM
I think I'm done for now? nieto1124 Excursion - King of SUVs 20 03-31-2015 12:04 AM
Mesquite Motor mania pic's theodore/teddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-18-2015 08:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
