Help dead battery - Ford Truck Enthusiasts Forums
Help dead battery
Old 08-17-2014, 05:22 PM
jayjjcc's Avatar
jayjjcc jayjjcc is offline
jayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to behold
Help dead battery
My Ex did this to me a few months ago 2 days in a row and then didn't do it again until now...
Battery is almost new and alternator charges fine but every once in a while when it sits it drains the battery. I can hear an audible click and rumble coming from the front end behind the drivers side headlight under the air intake.
I've got a boost coming but I'd like to be able to start her up again to go to work later.
Old 08-17-2014, 06:10 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Well the battery "was" almost new. Not anymore. Yes, that sucks. In fact the battery "may" be junk now. Discharging an auto start battery, even a couple times, kills them quick.
What you want to do is perform a parasitic load test and find out what's drawing down excessive. Power door locks, rear wipers, aftermarket sound systems are the usual suspects. You'll need a digital voltmeter that measures milliamps. Keep the battery on a charger till you get that sorted out (assuming it passes a load test and isn't shorted out internally, etc) It's important to remedy this because a bad battery can damage a good alternator.. Which will eventually damage a good battery, which.. Well you get the idea.
Battery Light comes on then off. Papa Charlie 1999 to 2016 Super Duty 11 07-08-2015 08:44 AM
Coil gets hot then bursts Fordtrucks123456789 1961 - 1966 F-100 & Larger F-Series Trucks 7 03-08-2015 10:27 PM
Passenger battery not charging. 99 7.3 bigbadbob17 1999 - 2003 7.3L Power Stroke Diesel 20 01-01-2015 10:23 PM
2004 f250 running and dash lights on after truck is shut off TheTinian 1999 to 2016 Super Duty 0 10-07-2014 09:03 PM
Battery terminal cleaning question nnero 2009 - 2014 F150 7 08-04-2014 05:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
