What pitman arm puller do you use ? - Ford Truck Enthusiasts Forums
Old 08-17-2014, 06:16 PM
DaytonaTunnel's Avatar
DaytonaTunnel DaytonaTunnel is offline
DaytonaTunnel is starting off with a positive reputation.
Looking to buy one, and I know our trucks have very large pitman arms. Wondering what you guys are using ?
Old 08-17-2014, 08:08 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
This puppy right here or the like.
3/4" Forged Ball Joint Separator
And a pickle fork. I have not encountered a pitman I couldn't remove since switching to this style of pitman arm tool.
Old 08-17-2014, 09:23 PM
lurch460's Avatar
lurch460 lurch460 is offline
lurch460 is gaining momentum as a positive member of FTE.lurch460 is gaining momentum as a positive member of FTE.
I have a MAC adjustable pitman arm puller. Fits them perfect, but thinking I need that tool CO425
Old 08-17-2014, 10:13 PM
Blue and White Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
I've never pulled the pitman on my dent but I'll comment based on other pitman's. I use a larger ~8" two jaw Sears puller. Back the nut off but leave it on loose to catch the pitman arm. Install the puller and tension it up well. Then give the shank of the puller a good wrap with a hammer. Has always worked for me.
Old 08-17-2014, 10:30 PM
4x4slik's Avatar
4x4slik 4x4slik is offline
4x4slik is gaining momentum as a positive member of FTE.
I just bought a large pitman arm puller from the parts store, but I had to loosen the bolts on the steering bear box to get it into place.
Old 08-18-2014, 12:26 AM
NBC-Steve's Avatar
NBC-Steve NBC-Steve is offline
NBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to behold
Snap-On!!!
Old 08-18-2014, 01:09 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
A large gear puller and a BFH...
Old 08-18-2014, 11:28 PM
NBC-Steve's Avatar
No but that will do the trick and its a fair price. (For a Snap On)
pitman arm Hyperactive460 WTB - Parts & other 2 11-21-2015 07:33 PM
pitman arm f250 or f350 enosez 1987 - 1996 F150 & Larger F-Series Trucks 3 11-06-2015 03:05 PM
Torque spec for pitman arm nut? flamesoldier 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 05-21-2013 10:59 AM
Pitman arm loose! 23larry24 1999 to 2016 Super Duty 2 04-07-2009 07:49 PM
Pitman arm removal Carlene 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-02-2002 03:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
