1997 f250 front tire wear - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-17-2014, 05:47 PM
winterkill winterkill is offline
winterkill is starting off with a positive reputation.
has anyone else seen bad wearing on their front tires? buddy has a f250 with the twin I front axle and hes going thru tires bad. he'd like to put a 6 inch lift but wants the tire wear to go away. does anyone know about a straight axle conversion? seems like this would solve the tire wear....
Old 08-17-2014, 08:43 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Sounds like his front end is shot
You can do a d60 swap
Old 08-17-2014, 08:57 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Very common with the TTB.
Most commonly it worn out parts an out of alignment
Things will wear out faster with a 6" lift
Old 08-18-2014, 08:32 AM
axle swap help
has anyone else done this swap. how hard are parts to find? what all is involved. thanks in advance
Old 08-18-2014, 09:06 AM
fordpride's Avatar
Old 08-18-2014, 09:11 AM
fordpride's Avatar
Old 08-18-2014, 10:28 AM
jchosler's Avatar
jchosler jchosler is offline
jchosler is starting off with a positive reputation.
Did my D60 swap and added a 4" lift. When finding a D60 it would be good to have it include the tie rod and draglink, leaf springs, and the matching rear axle to avoid changing gears esp if your buddies truck isnt already setup with 4.10 gears. I used all those parts on mine plus new larger shocks. Everyone also told me I needed a new driveshaft in the front but my F250 shaft bolted up fine, not sure if it depends on the truck or not.
Old 08-19-2014, 04:05 AM
Thor'sHammer's Avatar
Thor'sHammer Thor'sHammer is offline
Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.
Or save yourself about $1000+ and just replace the worn rubber bushings in the leaf spring eyes and the axle pivots with polyurethane ones. They cost about $60 and a few hours of your time. There's nothing wrong with a TTB if you maintain it. A ton of pain can be avoided by just replacing these bushings with polyurethane ones.
Old 08-19-2014, 07:28 AM
fordpride's Avatar
Quote:
Butt doing the lift that the op stated with a ttb will be further issues
Old 08-19-2014, 07:52 AM
How so? All you are doing with a lift is lowering the hinge points and installing new springs. The additional weight of the wheels won't affect anything either. I've owned 3 lifted TTB trucks with ZERO problems after all of the bushings are changed. As long as you fix the problems first, then lift, it will be fine.
Why are front tires wearing on the outsides? hail destroyer 1973 - 1979 F-100 & Larger F-Series Trucks 12 Yesterday 11:18 AM
uneven tire wear right front tire,2010 F250 richie25rich 1999 to 2016 Super Duty 3 10-13-2016 02:32 PM
1993 ford f250 2wd solid front axle ward5kustomz 1987 - 1996 F150 & Larger F-Series Trucks 24 12-24-2013 01:39 PM
inside tire wear - camber adjustment billj6 Ranger & B-Series 11 10-26-2008 08:15 PM
More Wear Front or Back tires? Musicman250 Brakes, Steering, Suspension, Tires, & Wheels 15 05-31-2004 07:02 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
