2004 expedition speedometer and shifting problem
Old 08-17-2014, 04:38 PM
dlsoc3's Avatar
dlsoc3
dlsoc3 is offline
I have a 2004 expedition with the 5.4l engine. The truck was built with 2003 parts however...it has the 4R70W transmission. The transmission failed and I replaced it with a junk yard transmission. After installing the new transmission my speedometer has stopped working and the truck will not shift past second gear. I removed the speed sensor from my original transmission and it still has not solved the problem. Does anyone have any insight to what may be happening? Cruise control will not light up on dash either.
Thank you
Old 08-17-2014, 08:02 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Take it to autozone or someplace like that and get them to read the codes. If you still have a VSS error code, you need to figure out why.
dlsoc3
1997-2006 Expedition & Navigator
09-08-2022 03:16 PM
Cday6104
12-06-2016 08:24 PM
iksebesta
12-05-2009 07:26 PM
Quick Reply: 2004 expedition speedometer and shifting problem
