Heavy duty tire question - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-20-2014, 07:36 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Michelin ltx a/t 2 is a good tire. High dollar though. Those are the all terrain ones. They also have a good street tread. Both 10 ply
Old 08-20-2014, 09:01 PM
Leatherneck007's Avatar
Leatherneck007 Leatherneck007 is offline
Leatherneck007 is starting off with a positive reputation.
Quote:
Originally Posted by tjc transport View Post
i would check with your local DOT before using recaps on the front.
they are against the law for use on steering axle in a lot of states.
Not in ND its not.
Old 08-20-2014, 10:21 PM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is online now
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
I've gotten a lot of miles out of Yokohama Geolander A/T and Cooper Discoverer A/T and their A/T3's. Over 50,000 miles a set on trucks that run around 14,000lbs (97 SuperDuty) on one, and 11,000lbs on the other (99 F350). 235/85R-16's. The 19.5 rims are a lot heavier, as are the tires. They have much shorter sidewalls, tires are much stiffer, so they're going to ride rougher.
Old 08-21-2014, 08:39 AM
gasman6674's Avatar
gasman6674 gasman6674 is offline
gasman6674 is gaining momentum as a positive member of FTE.
I am running Firestone TransForce on my 96 and have been very happy with them.
Old 08-21-2014, 09:06 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
I've been really pleased with the Nitto Crosstek tires I have on my truck as well. They're a load range E tire rated for about 3100 lbs each and so far they have worn really well. They're not overly noisy and on-road feel is really good. They don't do too badly in light offroad situations either. They aren't the best I have had in the snow, but I doubt the OP will have to worry about that too much, lol. The only downside is that they don't make them in a 17" size. I'm not sure what the OP is running for wheels, but they are only available in 17", 18" and 20" sizes. That may be a deal breaker for many, unfortunately.
Old 08-22-2014, 02:09 PM
dieselsubmariner's Avatar
dieselsubmariner dieselsubmariner is offline
dieselsubmariner is starting off with a positive reputation.
Thank you guys as usual for all the info. I'm still not sure, what brand to go with. I realy would like to find some realy high mileage tire, similar to semi truck tires.
One more question here: what is the max width I can run without rubbing the dually's and without any spacers? I currently run 215.
Old 08-22-2014, 02:20 PM
cgrutt cgrutt is offline
cgrutt is gaining momentum as a positive member of FTE.
I was going through a ton of tires on my 08 F350, predominately in rear. I think tire pressure had to be set at 80lbs and was causing premature wear. Unfortunately, the TPMS would not allow me to lower pressure so I dealt with it. I had a couple sets of Michelin LTX A/T 2s and loved them. They were pricey but had a great ride and were very good in bad weather and snow. Goodyear makes a commercial truck tire that is used predominately in delivery vans, etc that is supposed to have long wear, but I never used it. I don't remember name think it was Duratrack or something like that. It was a 10 ply E rated tire though. Good luck.
Old 08-23-2014, 02:06 AM
[quote=dieselsubmariner;14604157]Thank you guys as usual for all the info. I'm still not sure, what brand to go with. I realy would like to find some realy high mileage tire, similar to semi truck tires.
One more question here: what is the max width I can run without rubbing the dually's and without any spacers? I currently run 215.[/quote]
235/85R-16 is a common size for many dually pickups.
Old 08-23-2014, 07:44 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
The problem lies with the rims.
2wd trucks use 5.00" offset wheels and 215s
Vans use 5.15" offset wheels and 215s
4wds trucks use 5.35" offset wheels and 235s
So 4wd trucks have almost 3/4 of an inch more space between the rear rims than the 2wds do. This allows for room for the bigger 235 tire
I suggest getting 4wd rims if you want to run a 235 and actually USE them
Old 08-23-2014, 07:54 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
X2 ^^^^^^^^
I have four 4wd rims on the rear of my truck and 2wd rims on the front to set the tires out and give it the wider stance in the front. I had the 4wd rims on the front and it looked like the tire set in too far. Made it look like one of those trucks the raliroad uses to run on the tracks! LOL! I have 235 tires on mine. For a 2wd though, I'd probably stay with the 215s.
Old 08-23-2014, 09:18 AM
OK..
did some more search on commercial tires yesterday and found some i like for my truck and they are available in the LT 215-85-16 E.. but ...., they are expensive:
Goodyear G949 RSA Armor Max.
anybody here used those?
New Tires Questions Rick Cargo 6.7L Power Stroke Diesel 16 05-22-2015 10:10 PM
New tires, Toyo OC HT "Tuff Duty" thedaddycat 1999 to 2016 Super Duty 9 04-18-2015 12:50 PM
Any opinions on Toyo tires? RasJr 1999 to 2016 Super Duty 6 07-28-2014 09:54 AM
Toyo Open Country HT with Tuff Duty truckfella 1999 to 2016 Super Duty 3 01-30-2013 04:13 PM
365/65/r16 Toyo Is anyone running these? CrzHelm Excursion - King of SUVs 25 10-06-2011 07:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
