Cam with speed density - Ford Truck Enthusiasts Forums
Old 08-17-2014, 05:02 PM
brandon mauldin brandon mauldin is offline
brandon mauldin is starting off with a positive reputation.
So iv got a 89 f150 that I'm puttin a new motor in. It's a 302 roller motor with stock gt40p heads and I'm lookin at adding a small speed density friendly cam. The cam I'm lookin at is a xe264hr from comp cams. Here are the specs
Rpm range:1500-5500
Valve timing:0.006
Lobe separation:112*
Intake centerline:108*
Valve lash intake:hyd-exaughst:hyd
Duration intake:264-exaughst:270
Duration @.050 lift intake:212 exaughst:218
Valve lift intake:0.544 exauhst:0.544
Lobe lift intake:0.321 exauhst:0.321
Will this work for what I need? With stock gt40p heads?
Old 08-18-2014, 11:36 PM
Any input??
Old 08-18-2014, 11:55 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Quote:
Originally Posted by brandon mauldin View Post
Any input??
Have you searched for any cam info in this forum??
Lots to read.
112 lobe separation is the limit. 114 lsa is more ideal for sd of our trucks. If you had a maf truck, the 112 may work ok. Your vacuum signal to the map sensor will pulsate, which you can sometimes get away with putting a restrictor inline with a fuel filter as a buffer, but you're just tricking it.
Cold starts will be the biggest issue. Once it's warm it will run better.
I suggest searching and reading. Lots of good info because this topic has been beaten to death over and over.
Cam questions JRS2 1987 - 1996 F150 & Larger F-Series Trucks 28 06-25-2016 08:02 AM
F1ZE-AA spring selection htownoag 1987 - 1996 F150 & Larger F-Series Trucks 4 04-16-2016 02:10 PM
Can someone run some desktop dynos for me? NIdude Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 04-14-2015 11:25 PM
89 cam and motor swap need some advice! brandon mauldin 1987 - 1996 F150 & Larger F-Series Trucks 24 08-24-2014 02:26 AM
How much HP and torque DarkWolf40 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 11-27-2004 03:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
