Roscoe first day out....... - Ford Truck Enthusiasts Forums
Old 08-17-2014, 04:05 PM
CDN Sharky's Avatar
CDN Sharky CDN Sharky is offline
CDN Sharky is starting off with a positive reputation.
So after working this truck for 20 years off and on I finally finished it. I did all the work myself but did but turnkey 347 Blueprint engine and new c4 tranny. Now the sad part I insured it 2 days ago and went to take it for its first drive to the store 2 miles..... made it 1 mile. Then white smoke out the left exhaust and instantly truck stalled, towed it home pulled spark plugs. Pictures tell the rest motor has 1 mile on it.
Old 08-17-2014, 04:07 PM
blue04.5's Avatar
blue04.5 blue04.5 is offline
blue04.5 is gaining momentum as a positive member of FTE.blue04.5 is gaining momentum as a positive member of FTE.
No bueno, sorry to hear that.
Old 08-17-2014, 05:35 PM
gatorfor88's Avatar
gatorfor88 gatorfor88 is offline
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
Looks like your blueprint engine wasnt blueprinted very well.
Old 08-17-2014, 05:37 PM
OldMetal's Avatar
OldMetal OldMetal is offline
OldMetal is gaining momentum as a positive member of FTE.
That don't look good at all!
Old 08-17-2014, 05:40 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Oh man that sucks! Is there a warranty?
Old 08-17-2014, 06:55 PM
turbohunter's Avatar
turbohunter turbohunter is offline
turbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant future
Crap
Did you hear anything from the engine.
That looks like parts flying around in there.
Old 08-17-2014, 07:28 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Ngeesh....
'Might wanna scope the #5 cylinder for foreign objects.
Alternatively, could the plug have had too much stick-out? Mis-boxed plugs are not unheard of.
Old 08-17-2014, 08:47 PM
papasmurf40's Avatar
papasmurf40 papasmurf40 is offline
papasmurf40 is starting off with a positive reputation.
Those plugs look way to long for a small block ford motor IMHO
Old 08-17-2014, 08:55 PM
skidoodave's Avatar
skidoodave skidoodave is offline
skidoodave is gaining momentum as a positive member of FTE.skidoodave is gaining momentum as a positive member of FTE.
Quote:
I agree, those look like long reach plugs more common to the new engines, not a vintage small block.
Old 08-17-2014, 08:59 PM
They are pretty long but you'd have to know which head was being used.
If I remember correctly there are at least three different lengths for SBs.
Old 08-17-2014, 10:54 PM
mikeo0o0o0's Avatar
If it was a plug length problem wouldn't the other plugs look just as bad?
Old 08-17-2014, 11:16 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
I like the flat black look (satin black??) looks bad ***!
Old 08-17-2014, 11:23 PM
HIO Silver's Avatar
Quote:
Depends if the crook of the electrode was oriented "just right" as to make contact with the piston.
Old 08-17-2014, 11:54 PM
Time to go get *****....leave this over to the nerds/
Old 08-18-2014, 10:36 AM
GM4WALLS's Avatar
GM4WALLS GM4WALLS is online now
GM4WALLS is gaining momentum as a positive member of FTE.GM4WALLS is gaining momentum as a positive member of FTE.
Did you pull the head to see what dmage has been done?
'07 Trailblazer SS swap in '51 Ford F1 giobizio 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 04-22-2016 02:42 PM
1979 F250 Rust Woes rlacan71 1973 - 1979 F-100 & Larger F-Series Trucks 13 08-19-2015 04:07 PM
"Iron-Man" influenced Bixenon Projector Retrofit Francis Fiel Appearance & Dress-Up 3 06-29-2015 01:37 PM
pictures of the 01 expedition fuel pump replacement via cutting through the floor Danny01Expo 1997-2006 Expedition & Navigator 11 06-11-2014 12:29 AM
WhiteOut's 01's V10 Build! WhiteOut FX4 1999 to 2016 Super Duty 0 04-02-2014 09:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
