Roscoe first day out.......
Old 08-18-2014, 09:37 AM
GM4WALLS's Avatar
GM4WALLS
GM4WALLS is offline
Originally Posted by HIO Silver
Depends if the crook of the electrode was oriented "just right" as to make contact with the piston.
Could also be one piston installed upside down. Depending on how it is dished.
Old 08-18-2014, 09:43 AM
skidoodave's Avatar
skidoodave
skidoodave is offline
I would first pull the valve cover on the affected side and take a look at the valves for that cylinder. Could be one of the valve keepers came off allowing the valve to drop into the cylinder. If everything looks ok on the top side then get your self one of those cheap harbor freight inspection cameras and have a look in the cylinder to see what happened. They're only like 60 bucks with the coupon and come in handy very often, you can even practice your gynaecology skills with it......lol.
If you don't find anything up top or in the cylinder other than a marked or broken piston then it's time to pull the pan and look at the rod cap. If it came loose then that rod can travel further up causing the piston to slap the plugs and valves. Did you do a proper break in of the engine? How was the oil pressure? You could have lost a rod bearing during break in which would allow the piston and rod some extended reach.
What plug number and brand were you running? Did you play with the cam timing when you built it?
I would put my money of spun rod bearing allowing excess rod travel and longer than normal plugs.
Old 08-18-2014, 01:27 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Ya have got to pull the head anyway, so just do it and let us know what ya find.
Unless there is still a warranty on it. Than don't touch it. Just have the engine builder
deal with it. If ya open it up any farther than pulling the plugs it will void any warranty.
And just pulling the plugs may well have done that already. They can and will use any excuse to void it if they can.
Old 08-18-2014, 03:59 PM
emeraldcoupe's Avatar
emeraldcoupe
emeraldcoupe is offline
that would be a good trick, I'd like to see that,lol
Old 08-18-2014, 04:14 PM
GM4WALLS's Avatar
GM4WALLS
GM4WALLS is offline
Not skirt side up...
Old 08-18-2014, 04:15 PM
blue04.5's Avatar
blue04.5
blue04.5 is offline
He means rotated 180 degrees, but I'm sure you knew that.
Old 08-18-2014, 04:18 PM
GM4WALLS's Avatar
GM4WALLS
GM4WALLS is offline
I am sure. Lol
Old 08-18-2014, 06:34 PM
emeraldcoupe
yeah, just playing around
Old 08-18-2014, 07:18 PM
CDN Sharky's Avatar
CDN Sharky
CDN Sharky is offline
The sparkplug is a champion C59YC .45 gap the one recommended by the engine builder. Bought the engine turn key from Jegs. I haven't pulled heads hoping for warranty. Just contacted Blue Print engines today so far so good very nice people. The motor is seized cant turn it over at all. Bad thing is I am in Northern Canada and shipping engine will cost me 600 bucks so hopefully they will let me take it apart and send detailed pictures try to diagnose that way. im sure that piston is done found 2 pieces of what I think is a valve in the intake under the carb.
Colour of the truck is Dead Rat Flat Black single stage.
Anyways which me luck on the warranty ill try to keep post updated with progress.
Old 08-18-2014, 10:24 PM
turbohunter's Avatar
turbohunter
turbohunter is offline
Well, that just sucks butt.
Good luck with the warranty deal.
Old 08-18-2014, 10:50 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Man, I hope these are stand up guys and they stand behind their work. Hope also, they do something about the freight and import duties.
Keep us in the loop.
Old 08-23-2014, 11:25 AM
CDN Sharky's Avatar
CDN Sharky
So far so good Great people at Blue Print Engines I talked to Ken a warranty tech late yesterday and he figures 100 percent warranty. He has to tell management on Monday then he will contact me with shipping info. Great outfit I will buy all my future engines from them from now on.
  #28
Old 08-23-2014, 11:36 AM
turbohunter
That's great news.
But don't get to excited yet.
A shoe could drop at any time.
  #29
Old 08-23-2014, 01:50 PM
paredneck33's Avatar
paredneck33
paredneck33 is offline
Subscribed to see how this all turns out. Great looking truck by the way. It sure is a real bummer that this happened.
  #30
Old 08-23-2014, 03:39 PM
TheStuffz's Avatar
TheStuffz
TheStuffz is offline
heya CDN Sharky, from Sask. I know what you mean by shipping pains!!
Hope warranty is good to you!
Quick Reply: Roscoe first day out.......
