1996 F250 4x4 starts, idles rough, dies in gear - Ford Truck Enthusiasts Forums
Old 08-17-2014, 03:38 PM
mustangnewby mustangnewby is offline
mustangnewby is starting off with a positive reputation.
While driving today I hit a large bump going 35 and my truck started to run rough and died. It will start and idle rough and then die when put in gear. I switched to the rear tank and it idled fine and ran in gear. What will cause it to run rough on the front tank and die in gear but run perfectly fine on the second tank?
Old 08-17-2014, 04:56 PM
49FarmallM 49FarmallM is offline
49FarmallM is starting off with a positive reputation.
Probably broke the pickup tube in the tank or the wire on the valve body that controls the selection of the tank. 460, 351, or 7.3l?
Old 08-17-2014, 05:04 PM
It's a 460.
Old 08-17-2014, 05:28 PM
I am still able to choose between both tanks. It idles normally w the rear tank, but idles poorly on the first tank. If I push the gas pedal on the first tank it stutters and is slow to respond.
Old 08-17-2014, 07:23 PM
Any other ideas?
Old 08-17-2014, 10:02 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Your truck has a high pressure pump in each tank. The front one may be weak. Rent a fuel pressure tester.
Old 08-19-2014, 02:47 PM
TTT anyone else?
Old 08-19-2014, 02:56 PM
Evan_P's Avatar
Evan_P Evan_P is online now
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
Listen to RLA. That will give you an idea of whats wrong. If you don't follow the testing we tell you to do you won't get anywhere...
Old 08-19-2014, 02:59 PM
Ok appreciate it, how many psi should I see?
Old 08-19-2014, 03:01 PM
Evan_P's Avatar
~32 at idle with the vacuum line attached to the regulator. When removed it should jump up to ~39 psi.
Truck will start but not stay running cold 2wilde4u 1999 to 2016 Super Duty 0 03-24-2016 11:15 AM
97 f450 superduty 7.5 gas will not start. imabass 1999 to 2016 Super Duty 1 03-14-2015 01:41 PM
f350 idle/fuel problem godtar02 1987 - 1996 F150 & Larger F-Series Trucks 14 12-29-2014 04:42 PM
engine runs idles rough,wont accelerate leonard600 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 09-02-2010 03:55 PM
rough idle 88 f150 351w nickh 1987 - 1996 F150 & Larger F-Series Trucks 2 10-21-2007 08:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
