1996 F250 4x4 starts, idles rough, dies in gear
Old 08-17-2014, 02:38 PM
mustangnewby's Avatar
mustangnewby
mustangnewby is offline
While driving today I hit a large bump going 35 and my truck started to run rough and died. It will start and idle rough and then die when put in gear. I switched to the rear tank and it idled fine and ran in gear. What will cause it to run rough on the front tank and die in gear but run perfectly fine on the second tank?
Old 08-17-2014, 03:56 PM
49FarmallM's Avatar
49FarmallM
49FarmallM is offline
Probably broke the pickup tube in the tank or the wire on the valve body that controls the selection of the tank. 460, 351, or 7.3l?
Old 08-17-2014, 04:04 PM
mustangnewby
It's a 460.
Old 08-17-2014, 04:28 PM
mustangnewby
I am still able to choose between both tanks. It idles normally w the rear tank, but idles poorly on the first tank. If I push the gas pedal on the first tank it stutters and is slow to respond.
Old 08-17-2014, 06:23 PM
mustangnewby
Any other ideas?
Old 08-17-2014, 09:02 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
Your truck has a high pressure pump in each tank. The front one may be weak. Rent a fuel pressure tester.
Old 08-19-2014, 01:47 PM
mustangnewby
TTT anyone else?
Old 08-19-2014, 01:56 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Listen to RLA. That will give you an idea of whats wrong. If you don't follow the testing we tell you to do you won't get anywhere...
Old 08-19-2014, 01:59 PM
mustangnewby
Ok appreciate it, how many psi should I see?
Old 08-19-2014, 02:01 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
~32 at idle with the vacuum line attached to the regulator. When removed it should jump up to ~39 psi.
drewdole
10-28-2017 11:54 AM
McKenny
02-24-2012 02:33 PM
flyflinger
2004 - 2008 F150
10-14-2009 01:12 PM
ghunt
06-10-2008 09:54 AM
boggerted
12-24-2007 11:31 AM
Quick Reply: 1996 F250 4x4 starts, idles rough, dies in gear
