88 4.9 oil pan / rear main - Ford Truck Enthusiasts Forums
Old 08-17-2014, 01:45 PM
Jhow88 Jhow88 is offline
Jhow88 is starting off with a positive reputation.
So i was confident my rear main was leaking and the clutch was gone. I have the transmission birthed (my first - I'm handing out cigars) and the clutch components out and the flywheel ready to go to the machine shop. Everything went awesomely smooth . But turns out the rear main is fine (I'm replacing anyway) but the oil pan appears to be seeping at the dip right under the rear main. From everything I've read the engine needs to be raised to change the oil pan gasket but is that safe with the transmission removed? Where should i go from here?
Edit: forgot to mention .. 2 wheel drive long bed
Old 08-17-2014, 01:52 PM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
Hang the engine from a 2X4 that's laying across the back of the engine compartment… that will hold 'er up while you drop the pan…
Old 08-17-2014, 07:05 PM
Thanks, great idea!
Old 08-18-2014, 06:11 PM
Good news! If you already have the transmission and flywheel off all you have to do is lower the pan and snake your hand in to unbolt the oil pump and pickup and it all slides out towards the back with ease.
Another rear main seal thread DrZoom 1987 - 1996 F150 & Larger F-Series Trucks 1 08-19-2015 02:42 PM
352 oil pan removal brbuchanan 1961 - 1966 F-100 & Larger F-Series Trucks 4 08-16-2015 09:17 PM
Engine rear plate mototrig 1999 - 2003 7.3L Power Stroke Diesel 3 09-25-2014 06:13 PM
rear main help northdakota 67ford 1967 - 1972 F-100 & Larger F-Series Trucks 15 06-16-2014 10:15 PM
3.0 oil pan gasket Taumac Ranger & B-Series 2 05-04-2012 03:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
