Towing upgrade - Ford Truck Enthusiasts Forums
Towing upgrade
Old 08-17-2014, 01:19 PM
mtntop1's Avatar
mtntop1 mtntop1 is offline
mtntop1 is starting off with a positive reputation.
Towing upgrade
I have a 1995 F150 5.0L engine.It has 3.55 rear end gears can I upgrade to 3.73 gears.If so would there be an improvement in low to mid range towing.
Old 08-17-2014, 01:33 PM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
You'd see a little more towing power but not a radical change…
When I had a '48 F-1 it had a stock Dana 44 rear gear… 4.44 as I recall. With a stock '56 Buick 322 engine I could leave the trans in 4th gear and slowly roll thru a stop sign, turn right and never have to upshift. I could gross 10,000 lbs. (yeah I know that's a lot) with a loaded trailer hauling scrap to my local salvage yard… no problem.
I switched the rear to a Ford 9" with a 3.70 gear. Now I needed to downshift to 3rd to make that same maneuver. Now I needed to run try my little town in 3rd gear to haul a lot of weight going to the scrap yard.
Later I installed a 2.75 gear since I was traveling a lot on the highway… that rolling stop was now a 2nd gear deal… and I didn't dare haul more than 2k in my truck/trailer combo as it just didn't have enough HP to pull the load.
My point is gears can change things a lot… but don't expect miracles.
Old 08-17-2014, 02:05 PM
mtntop1's Avatar
If I do upgrade can I just change the ring and pinion gear
Old 08-17-2014, 02:11 PM
Nothing Special's Avatar
Nothing Special Nothing Special is online now
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
3.55 to 3.73 is about a 5% gear reduction. Most overdrive transmissions are at least 20%, and usually closer to 30%. So that change would be about 1/6 to 1/4 of the benefit downshifting from OD to direct drive would give. Would it help? Yes. Would the small improvement be worth the cost of the gear change? Doubtful.
If you're going to pay for a gear change you might want to go farther to get more bang for the buck. 4.10 gears would be a 15% reduction. That's starting to get more significant. Or 4.56 gears would be a 28% reduction.
Then again, how often do you tow? If you tow a lot you probably want something other than a 302, so I'm guessing it's not a whole lot. As long as you have a lower gear in your trans you can get the benefit of regearing your axle for free, just by downshifting. The only place this doesn't help is starting from a dead stop when you're already in your lowest gear. But if you can get the load rolling in first you can save yourself some money just by not using your highest gear.
Old 08-17-2014, 02:57 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Waste of time/money. That is so little change.
Put 4.10 in
Old 08-17-2014, 03:06 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Put 4.10 in
I agree...
When it comes to gear swaps go big or stay on the porch.
Old 08-17-2014, 03:12 PM
Quote:
You can "just" change the ring and pinion, but the word "just" doesn't mean it's a small job. Figure around $1000 parts and labor, or around $300 - $400 for parts if you can set up gears yourself (and that's sort of one of those "if you have to ask you can't do it" sort of things)
Old 08-19-2014, 04:13 AM
Thor'sHammer's Avatar
Thor'sHammer Thor'sHammer is offline
Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.
Quote:
Very true. Also, if you've set ever set up reverse cut gears before, you'd know it's much, much more involved than the rear set.
Old 08-19-2014, 04:48 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
How much weight are you towing? What diameter tires do you have now?
I've done the equivalent to a 3.54 to 3.73 swap by changing tire sizes, & the difference was ideal for me..........but that was with a 351W.
The advantage with this is you can easily & cheaply swap back & forth to get the best option, without being locked in to just one.
For example - on a truck with your gearing, swapping from 31" to 27" tires will gain 300 rpm @ 55mph.
But if you are going to tow heavy loads/steep terrain, a tire change probably won't give you enough gain.
Old 08-19-2014, 03:16 PM
Old Trusty's Avatar
Old Trusty Old Trusty is offline
Old Trusty is starting off with a positive reputation.
I have 1/2ton work truck with 4.10s in it and a 5.3 v8 (chevy) and it out pulls the other 1/2ton with the 5.7 v8 (chevy) but it has 3.73s. If you are going for a permanent gear change go to 4.10s, but if you want the best of both worlds I agree with Ken get a set of Steels and put some small 10 plys on them so you can easly change in the driveway after that. I haven't towed with my signature truck yet but I am interested to know how the 3.55s do, keep us posted Mtntop.
Best gears for v10 with 35'' and towing tires? traildogg 1999 to 2016 Super Duty 17 10-20-2015 11:13 AM
MaxTow with HD Payload vs. Tow Package with HD Payload Ottawasteve 2015+ F150 3 03-20-2015 11:28 AM
Nothing to tow is killing me DrunkTruck 1999 - 2003 7.3L Power Stroke Diesel 17 03-16-2015 05:27 PM
2000 F150 gear ratio Amonshax 1997 - 2003 F150 2 08-05-2010 12:32 PM
what gears on 2001 f350 8 inch lift and 37's robjs111 1999 to 2016 Super Duty 9 09-02-2007 10:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
