Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Interior Specifications
Important information to help you understand your Ford truck
F350 suspension height specifications
Your truck is old.... It's worn out and sagging. The end. If it rattles and clunks, it's obvious the bushings are shot. Why do you need exact heights. My truck is shorter than others of the same year, not because it's sagging, but because apparently my grandfather ordered it that way. He was a short person. Not sure if it's true, but the front tires wear perfectly across, so it can't have sagged too much, and it's a good 2" shorter than my coworkers truck of same generation.
Are you planning on replacing springs and you want something to go by, or does it just sit crooked, or tires have too much camber... My 92 2wd 4door sits super low. I put 265s on it to raise it up a little. But that one also wears tires nearly perfect.
ok.. maybe i need to be specific:
YES i did do a google search.
No my bushings are not wore out. except the sway bar bushings on the rear axle.
Tires wear evenly.
As for the height: I believe my front springs have sagged over the years as well as my rear springs. but before i purchase new springs, i wanted a reference to see, how much they sagged. If it is only minimal, than I’m not buying springs.
thanks a lot for any input
Tires wear evenly.
LargeFarva97
05-12-2018 01:37 AM
Jeremy757
16
12-31-2014 08:58 AM
Wittmer321
08-08-2006 02:15 AM
