NO START AFTER WVO.......
I have been running WVO for about 6 years in my 2000PSD CC/LB, and run a golden fuel system....
I recently had the WVO tank out for body and paint work, and it was out for about a month. I installed the tank and hooked everything back up today, filled the tank with clean WVO and a new filter......I drove it, switched her over to VEG and after about 20 minutes, it quit running. It acted like there was air in the lines and shuttered to a halt. It was to be expected there be air in the lines, and I didn't purge it before startup....so this is where I am...
I drained the fuel bowl, switched it back to diesel and sat on the side of the road and cranked it over after cycling the key.....It was popping, but not starting. I removed the fuel bowl filter, drained the fuel bowl and made sure I was getting fuel into the bowl. I again drained the bowl, filled it back up with fresh diesel and replaced the filter, as I have done several times in the past with out problems....I cannot get her to start. It just cranks.
any suggestions?
any suggestions?
90pioneer
6.7L Power Stroke Diesel
11-22-2017 06:55 PM
imjwm
07-07-2015 12:24 PM
bubbagilkes
10-13-2009 08:45 PM
wolfmanagh
Bio-diesel, Propane & Alternative Diesel Engine Fuels
12-14-2005 11:50 AM
