My 97 F150 - Ford Truck Enthusiasts Forums
My 97 F150
Old 08-17-2014, 12:54 AM
shadowvox6 shadowvox6 is offline
shadowvox6 is starting off with a positive reputation.
Smile My 97 F150
I have really enjoyed the first few months of owning my F150.
While I thought I was going to pull my hair out at points....I got the truck the way I want it (for now)
Been a battle....
I bought the truck in March....paid $1000 for it.
Had ~ 190k with ~ 90k on a replacement motor.
It was used for a lawn care business for over 10 years.
Since then, I have done the following:
Maintenance:
-New brakes (pads, rotors, shoes, drums)
-Flushed the brake fluid
-Installed Axle Repair Bearings, and replaced the diff cover
-Replaced the Pitman Arm, and front sway bar links
-new upper control arms (with new upper ball joints)
-new shocks
-new tires
-new serpentine belt & belt tensioner
-new coils, plugs (Motorcraft Platinums), new wires
-swapped out all the fuel injectors with a set that I soaked in Seafoam for a couple of days to clean them.
-New PCV
-New radiator
-dropped the trans pan, did the fluid and filter. One month later, had the system flushed
-flushed power steering fluid
-replaced the fuel pressure regulator, fuel pump, fuel filter
-replaced the front grille
-did a full Seafoam treatment (through the intake)
-Replaced the upstream O2 sensors
-Replaced the alternator
Modifications:
-Superchips MicroMax tuner
-Maxbore modified TB
-"Gotts Mod" intake modification with the silencer removed from the intake tube
-Hypertech 160* thermostat
-Kenwood KDC-318BT head unit
-Navigator "Premium" package component speakers
-Navigator cluster with LED's installed
-Flowmaster knock-off (cheap Chinese) muffler with side exit exhaust
-"Lighting" style headlights with 7000k Nokya 80/100w 9007 bulbs with heavy duty harness
-Bed Liner
Hopefully now I can just drive it and enjoy it!!
Old 08-17-2014, 12:56 AM
FWIW, my mileage has increased over 2mpg since when I got it.
Also, it runs eleventy billion times better!!
Old 08-17-2014, 01:05 AM
I have also had my last engine oil change analyzed by Blackstone labe
Made me feel better for sure!!
Old 08-18-2014, 12:13 AM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
any pictures of the truck?
Old 08-18-2014, 07:48 AM
From our recent vacation
Shortly after I bought it back in March
Old 08-18-2014, 08:35 AM
Dr. Dirt's Avatar
good looking truck now! sure is coming together.
Old 08-30-2014, 07:20 PM
thzpcs thzpcs is offline
thzpcs is gaining momentum as a positive member of FTE.
I absolutely love that color! Beautiful truck man.
Old 08-31-2014, 01:01 AM
F91 F91 is offline
F91 is starting off with a positive reputation.
Really nice work!! What shocks did you go with? Amd when you did your fuel pump, did you drop the tank or remove the bed?
Need help with pricing - selling carver94f350 N. California Chapter 4 10-21-2015 03:29 PM
Need Help upgrading 88 F150 Adam Spurgeon 1987 - 1996 F150 & Larger F-Series Trucks 4 07-31-2015 09:33 AM
2000 2.5 Ranger Detonation Issues SHOpar Ranger & B-Series 1 01-23-2015 12:26 AM
P0304 Misfire (Don't know what more to do) ChaosClown 1997 - 2003 F150 65 11-14-2011 07:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
