2004 F250 HPOP Screen, Metal Contamination
Old 08-16-2014, 10:20 PM
1994F2507.3L's Avatar
1994F2507.3L
1994F2507.3L is offline
New to 6.0, I'm a detroit mechanic, and have experience with the 7.3
was getting codes for EGR, decided to do bulletproof EGR cooler, hooked up Insight CTS from my 97, found oil temps north of 235. Ordered oil cooler kit. went through teardown today, found the HPOP screen torn on one of the sections, and metal both steel (magnetic), and probably aluminum on the remaining screen sections. cut the oil filter in half and looked through it found metal shavings, again magnetic and non magnetic in the oil filter. owner complaint of engine miss though i did not experience it.
the question i have is would this be a lower bearing issue or be originating in the HPOP and injection system?
Old 08-16-2014, 10:33 PM
cheezit's Avatar
cheezit
cheezit is offline
You may not like my awnser but here ya go. There is a small amount of metal flow and its normal. Now if your seeing copious amounts thats another issue.
You will see signs of some metal in the filter housing.
Torn screens under the oil cooler are common, they do like to deposit debris in the ipr more frequently when that happens.
2006White60
12-14-2015 12:22 PM
autonoz
09-01-2011 07:53 AM
dzlbuck
06-21-2011 08:03 PM
landis76
1999 to 2016 Super Duty
05-10-2010 05:20 AM
Silverrv
12-10-2008 03:38 PM
Quick Reply: 2004 F250 HPOP Screen, Metal Contamination
