2004 F250 HPOP Screen, Metal Contamination - Ford Truck Enthusiasts Forums
Old 08-16-2014, 11:20 PM
1994F2507.3L's Avatar
1994F2507.3L 1994F2507.3L is offline
1994F2507.3L is gaining momentum as a positive member of FTE.1994F2507.3L is gaining momentum as a positive member of FTE.
New to 6.0, I'm a detroit mechanic, and have experience with the 7.3
was getting codes for EGR, decided to do bulletproof EGR cooler, hooked up Insight CTS from my 97, found oil temps north of 235. Ordered oil cooler kit. went through teardown today, found the HPOP screen torn on one of the sections, and metal both steel (magnetic), and probably aluminum on the remaining screen sections. cut the oil filter in half and looked through it found metal shavings, again magnetic and non magnetic in the oil filter. owner complaint of engine miss though i did not experience it.
the question i have is would this be a lower bearing issue or be originating in the HPOP and injection system?
Old 08-16-2014, 11:33 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
You may not like my awnser but here ya go. There is a small amount of metal flow and its normal. Now if your seeing copious amounts thats another issue.
You will see signs of some metal in the filter housing.
Torn screens under the oil cooler are common, they do like to deposit debris in the ipr more frequently when that happens.
Missing piece of Oil Cooler screen MN_Andy 6.0L Power Stroke Diesel 5 07-07-2016 11:21 PM
2006 F250 6.0, metal in motor - is it dead? njfirefighter15 6.0L Power Stroke Diesel 25 08-19-2015 03:31 PM
Oiling system upgrades/maintenance the_auto_tech 6.0L Power Stroke Diesel 10 01-20-2015 10:47 AM
IPR valve torque spec and positioning pswann64 6.0L Power Stroke Diesel 15 05-23-2014 07:30 PM
Metal shavings on IPR screen? Piolet 6.0L Power Stroke Diesel 0 02-20-2013 09:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
