Keys
Old 08-21-2014, 06:53 AM
Shadowrider123's Avatar
Shadowrider123
Shadowrider123 is offline
Keys
My 64 F100 and 65 Mustang use the same ignition and door lock cylinders.
Is it possible to have them keyed the same?
PITA keeping up with a bunch of keys.
Old 08-21-2014, 10:31 AM
sseebart's Avatar
sseebart
sseebart is offline
A good locksmith should be able to rework the cylinders. I had multiple keys for my 64 tbird (door and ignition were different--go figure!) and had the cylinders done for about $20 each, after I removed them myself.
~Steve
Old 08-21-2014, 12:30 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The ignition and door lock keys are the same, but the cylinders are not the same.
1961/66 truck uses the same cylinders as 1961/64 Galaxie, 1965/66 Mustang uses the same cylinders as 1965 Fairlane/Falcon.
In order to have both vehicles keyed alike, you'll have to remove all the cylinders and have a locksmith replace the tumblers.
Old 08-21-2014, 05:18 PM
jowilker's Avatar
jowilker
jowilker is offline
If the key form one will fit the other, (your first clue) a locksmith can repin one with the key from the other, to make one key work in both.
John
milkstake
06-14-2017 07:04 AM
Tedster9
01-27-2015 12:35 PM
tiny terror
07-05-2009 05:42 AM
Michael Sizemore
05-05-2004 06:46 AM
sbryant
10-03-2002 07:36 AM
Quick Reply: Keys
