Driveline lengths
Old 08-16-2014, 09:52 PM
mositso's Avatar
mositso
mositso is offline
Driveline lengths
I have a 78 f250 crew cab 4x4 automatic 400 cu. It's a fixer upper that I purchased with drivelines sitting in the bed of the truck. I have finished some engine work, exhaust work, body work, and one to drive train. I replaced all u joints, carrier bearing, and proceeded to install the drivelines. Well in short the rear driveline does not fit. So lengths will help me determine if it's wrong drivelines, or reinstall of carrier bearings was wrong. I need lengths of the three drivelines.
Old 08-17-2014, 02:23 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
How much to short is it? Here is an Super Cab for an example, have you posted this question in the CC forum (top of the this forum list)?
https://www.ford-trucks.com/forums/7...ly-thread.html
I am sure you have slid the yoke out a bit haven't you, if its just to short by an 1" or 2"?
Old 08-17-2014, 06:06 AM
jim collins's Avatar
jim collins
jim collins is offline
Yeah , how short is it ? It has to be a little short for the axle to go up and down with out binding. You may know that but we don't know that you do or how much experience you have mechanically .
Old 08-19-2014, 07:49 PM
mositso's Avatar
mositso
mositso is offline
My bad, not short, too long
The driveline is 62.5 inches long outside knuckle to knuckle, about 61.25 inches center of u joint to center of u joint. The driveline is 1.25 inches too long. I will attach photos soon.
Old 08-19-2014, 08:56 PM
mositso's Avatar
mositso
mositso is offline
1 1/4 or 1 3/8 to long.
Old 08-19-2014, 09:05 PM
mositso's Avatar
mositso
mositso is offline
61.25 from u joint to u joint
Old 08-19-2014, 09:09 PM
mositso's Avatar
mositso
mositso is offline
62.5 from knuckle to knuckle
fordrealdrive's Avatar
fordrealdrive
fordrealdrive is offline
Does your truck still have the original D60 rear axle, or has it been swapped?
Old 08-19-2014, 09:54 PM
mositso's Avatar
mositso
mositso is offline
I am unsure if it is the original axle. But I am sure it is a Dana 60. The bolting patter of the housing matches a Dana 60. Unfortunately the Tag for model # and gear ratio are rusted looking.
Old 08-19-2014, 10:09 PM
fordrealdrive
That cancels my theory of a sterling being swapped in.
On a side note...it's better to be too long, than too short. It's cheaper to shorten, than to retube the d-shaft.
GBuckert
01-11-2013 07:58 AM
crazyredneckanyhow
1999 to 2016 Super Duty
15
11-18-2010 12:40 AM
BigJake34452
12-01-2009 10:16 AM
kawika
21
08-04-2007 09:25 PM
joeshmo
06-25-2007 01:29 PM
Quick Reply: Driveline lengths
