1979 Dana 60 Front Alternative? - Page 2 - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Log In
Old 08-20-2014, 07:58 AM
somethingclever's Avatar
somethingclever somethingclever is offline
somethingclever is gaining momentum as a positive member of FTE.somethingclever is gaining momentum as a positive member of FTE.
I think the axle tubes of the 3/4 ton d44 are larger than the 1/2 ton counterparts thereby they could be called HD if one was so inclined. They were rated at a higher weight.
__________________
1978 F250 4x4 Super Cab - 400, C6, NP205, 3.55, Dump and Plow - Work Horse
1979 F250 4x4 Crew Cab - 466, T18, NP205, 4.88, 9" lift, 40" toyo's - FAMILY WAGON
Old 08-20-2014, 08:40 AM
ShaneNP123's Avatar
ShaneNP123 ShaneNP123 is offline
ShaneNP123 is starting off with a positive reputation.
Every 8 lug D44 I've ever seen on most forums has always been referred to as a D44 HD.
__________________
'79 F-100 2wd 300/T-18/D44
'80 F-150 Flareside 302/T-18/NP208 Dana 44 SAS
'55 F-250 360/C6
'91 F150 Supercab 5.0/M5od/4x4
Old 08-20-2014, 09:34 AM
Higbean's Avatar
Higbean Higbean is offline
Higbean is starting off with a positive reputation.
Quote:
Agreed. When I sold mine I looked around a bunch to see what they were worth and that is how every one of the for sale adds was listed. That is how I listed mine and that is how I refer to those axles.
Old 08-20-2014, 12:03 PM
fordcrzymike's Avatar
fordcrzymike fordcrzymike is offline
fordcrzymike is gaining momentum as a positive member of FTE.fordcrzymike is gaining momentum as a positive member of FTE.
I also have always referred to the 8 lug (F-250) D44s as HD D44s. The outers are different, as well as the pumpkin casting and weight ratings. Sounds HD to me...
__________________
1979 Ford F-250 Custom 4x4 400 NP435 NP205 - Project
400 Engine Build
1997 Ford F-150 XLT Scab 4x4 Off Road 4.6L 4R70W - DD
Old 08-21-2014, 08:06 PM
NorthwestX360's Avatar
NorthwestX360 NorthwestX360 is offline
NorthwestX360 has a very good reputation on FTE.NorthwestX360 has a very good reputation on FTE.NorthwestX360 has a very good reputation on FTE.
Here's a Dana 60 for sale in Oregon: 1978/79 dana 60 high pinion king pin front axle ford
__________________
1979 F350 4X4 Supercab Lariat flatbed
1978 F250 2WD Regular cab Ranger
1997 Dodge/Cummins 2500 4X4 Club Cab
Old 08-21-2014, 10:26 PM
Higbean's Avatar
That would save a guy some $$. Even with a gear change.
Old 08-21-2014, 10:38 PM
fordrealdrive's Avatar
fordrealdrive fordrealdrive is offline
fordrealdrive is gaining momentum as a positive member of FTE.
cbfwd@yahoo.com
I wonder what's up with the track bar, and did anyone notice the extra tall/hugely angled/spring pads?
Castor angle is way off unless the inner C's have been reset.
__________________
Chris
'79 F350 ranger lariat supercab 4x4-400-4spd-205-4.10's-6"lift-38.5"tires
'76 F250 4x4 w/'77cab 460-4spd-205twinstick-D60 frt detroit locker-HD70 rear welded-4.10's-1350 series D-shafts-10"lift (25 year never ending project)
Old 08-21-2014, 10:42 PM
Higbean's Avatar
I think you might be right. The angle of the C's looks way off to my eye.
Old 08-21-2014, 11:17 PM
cbfwd@yahoo.com
Quote:
If this is the case, it would steer/handle terribly. All that work and money and still push/pull type steering too
__________________
Chris
Similar Threads
cost effective truck transport long distance? curtisheth 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 01-31-2015 03:52 PM
Introduction 1981fordstepside 1981fordstepside Manitoba / Saskatchewan Chapter 13 06-24-2014 06:13 PM
Looking to buy and Excursion 97anny Excursion - King of SUVs 5 10-16-2013 10:53 PM
A pair of local 53 M-350`s for sale Fomoko1 Manitoba / Saskatchewan Chapter 0 08-06-2013 08:22 PM
REMANUFACTURED 04-06 POWERSTROKE 6.0L Fomoko1 Manitoba / Saskatchewan Chapter 75 01-09-2011 05:59 PM
Tags
1979, alternative, dana, differential, f250, front
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
