1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2000 EB - Removing front torsion bars for lower ball joint replacement
Old 08-15-2014, 05:19 PM
fred_79f250's Avatar
fred_79f250
fred_79f250 is offline
Hello,
Been a while. But now the time has come to replace the lower ball joints on my 2000 XP (5.4l, 4wd, EB).
I've got everything undone, except the torsion bars. I got the tensioner screws and brackets out. But darned if the things will budge. I've been putting penetrating oil on them for days, and banging on 'em with a small sledge - no move. I put a soldering torch to one - no move.
The instructions in the Haynes speak of simply sliding them out of the lower control arm, forward, until they clear the cross member. Very funny.
Since I have to toss the whole control arm with the integrated ball joint, I'm thinking of taking a sawzall and cutting the section where the torsion bar goes in. But before I do that - does anyone have any good tricks to get these things out?
Thanks.
Old 08-16-2014, 02:05 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
You don't have to do any of that to replace the lower ball joints. The uppers are made into the control arms but the lowers are pressed in. No need to remove the torsion bars. The shock will keep the arm in place.
Old 08-16-2014, 02:31 PM
SilverSS's Avatar
SilverSS
SilverSS is offline
^^^+1. Just make sure it's a good tight fit. I had to get an oversized one for the driver side on mine...
Old 08-16-2014, 03:25 PM
fred_79f250
Thank you, gentlemen, for confirming this. In the meantime I did some research and came to the same conclusion and have gone out and bought the ball joints and borrowed the press kit. Always good to have independent confirmation that what you think is ok really is.
And, at least with the torsion bar pressure released it's worry free.
Old 08-17-2014, 12:26 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
I'll bet it's a lot more funny now that you know the ball joints press out.
jhurd12
07-16-2008 02:48 PM
cchev
05-02-2008 06:17 AM
bigtoe68
1983 - 2012 Ranger & B-Series
10-11-2005 08:09 PM
Neumech
Michigan Chapter
12-15-2004 04:20 PM
Quick Reply: 2000 EB - Removing front torsion bars for lower ball joint replacement
